OBD2 D16a VTEC JDM ECU with Engine swap?
Old 09-22-2016, 02:03 PM
GS_Performance's Avatar
Default OBD2 D16a VTEC JDM ECU with Engine swap?
I have a few questions about this swap. I am swapping out the d16y8 (rod knock) from a 98 civic ex to the obd2 d16a vtec. This car is an auto and I found the auto ecu for this engine (d16a) for $45. So the questions I have are, could I theoretically just swap the usdm ecu with the jdm ecu and put this d16a in and have no issues? Would it all be plug and play or would I have to depin anything from the harness or change anything at all? I know if I kept the y8 ecu I read I would have to depin and do the ckp trick and change oil pumps?, but if I just jump straight to the d16a jdm ecu I assume none of that is necessary and it should make this swap a plug and play correct?
Old 09-22-2016, 04:25 PM
Fish Twig
tony_2018's Avatar
Default Re: OBD2 D16a VTEC JDM ECU with Engine swap?
which transmission are you going use?
Old 09-22-2016, 04:27 PM
I would use the USDM d16y8 auto trans
Old 09-22-2016, 07:05 PM
Fish Twig
tony_2018's Avatar
Use the usdm ecu.
Old 09-23-2016, 08:00 AM
So then I have do do the CKP trick right? Also I read somewhere I have to change the oil pump is this true?
Old 09-25-2016, 11:31 AM
GDD Member
slomofo's Avatar
CKP & oil pump differences are for OBD1-OBD2 and vice versa.
If you're going from OBD2 to OBD2, that stuff is irrelevant.
Old 09-26-2016, 08:27 AM
The importer I am getting the engine from said OBD2 D16A doesn't come with CKP so I am not sure if maybe it is actually and obd1 or what.
Old 09-26-2016, 09:19 AM
GDD Member
slomofo's Avatar
Guess you'll just have to wait and see then.
Old 09-26-2016, 12:49 PM
I worked out a deal with my importer for the ecu so I will try and see what happens.
Johnsonthe3rd
03-10-2011 11:45 AM
vinuneuro
05-25-2009 12:54 PM
EE_Chris
06-12-2004 02:43 PM
silvershiny-ek
05-15-2003 08:00 AM
Quick Reply: OBD2 D16a VTEC JDM ECU with Engine swap?
