obd1 or obd2
Old 10-17-2006, 08:56 PM
importtuner07's Avatar
Default obd1 or obd2
ok i want to build up a b18 gsr engine to drop in my 1994 Honda Civic Ex and my friend has a 1996 GSR that he is gonna let me have and i was wondering to just make it easier is it possible to just put and obd1 cylinder head so i don have to mess with all the sensors Thanks for any help or advice. I am running a B16a right now.
Old 10-17-2006, 09:00 PM
t0p_sh0tta's Avatar
Default Re: obd1 or obd2 (importtuner07)
Don't swap heads.
Ignore the sensors and use an OBD-I ecu.
Search the FAQ.
Old 10-17-2006, 09:08 PM
cambopheonix56's Avatar
Default Re: obd1 or obd2 (t0p_sh0tta)
If you are going to build it up, you will need a tune so it will be easier obd1.
Old 10-17-2006, 09:25 PM
HT Order of Merit
JDM_Ej's Avatar
Default Re: obd1 or obd2 (cambopheonix56)
What sensors? The GSR engine will wire up using your OBD1 harness, just swap the distributor, (and maybe the injectors). Everything else plugs in.
Old 10-17-2006, 09:29 PM
t0p_sh0tta's Avatar
Default Re: obd1 or obd2 (JDM_Ej)
Aside from the knock sensor.
(I'm probably forgetting something else)
D-series FTW!
Old 10-17-2006, 09:32 PM
the knock sensor can i just ignore that and wire it up with my harness that i have
Old 10-17-2006, 09:33 PM
t0p_sh0tta's Avatar
The OBDI ecu doesn't look for the knock sensor.
Just let it sit in the block, or remove it if you like.
No harm, no foul.
Old 10-17-2006, 09:39 PM
HT Order of Merit
JDM_Ej's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">The OBDI ecu doesn't look for the knock sensor.
No harm, no foul.</TD></TR></TABLE>
Depends on the ECU... P30's check for knock sensors, and so do P72's. If your using a chipped P28, then don't worry about it.
Old 10-17-2006, 10:03 PM
t0p_sh0tta's Avatar
I had the p28 in mind when posting that.
I should have mentioned it though... =P
hondachris1994
10-11-2008 10:00 AM
eh2
05-06-2007 07:25 AM
simonsays
12-23-2006 05:51 PM
s2000june
12-19-2004 04:16 AM
colombian linx
09-04-2004 06:44 PM
Quick Reply: obd1 or obd2
