install a eg carbon fiber hatch?
Old 06-22-2004, 07:41 PM
93jdmhatch's Avatar
Default install a eg carbon fiber hatch?
today i just got my CF hatch for my 93 civic hatch....it looks like a pain in the *** to put on..its prob not..just that there is alot of parts back there and i dont know how to do it...has anyone done this before....i have searched and nothing...let me know
Old 06-22-2004, 07:50 PM
Global Moderator
Jimmy's Avatar
Did it not come with instructions?
Old 06-22-2004, 07:52 PM
93jdmhatch's Avatar
Default Re: (Jimmy)
nope
Old 06-22-2004, 08:26 PM
rodrez.'s Avatar
Default Re: install a eg carbon fiber hatch? (93jdmhatch)
Back when I had one, I just layed the CF tail gate on a blanket on the ground, opened the stock hatch, took off the plastic panel, and started transferring parts over one by one to the CF one, slightly bolting them on (finger tight). Starting with the metal bars that release the tail gate, I disconnected those, removed the latches on the side, and pulled the bars out, then the lock mechanism, then the tail lights and pulled the harness through the hole, then bolted the new tail gate to the car and and tightened everything up, also aligned/adjusted it so it closed completely.
Old 06-22-2004, 08:30 PM
mjrage's Avatar
Default Re: install a eg carbon fiber hatch? (rodrez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez &raquo;</TD></TR><TR><TD CLASS="quote">Back when I had one, I just layed the CF tail gate on a blanket on the ground, opened the stock hatch, took off the plastic panel, and started transferring parts over one by one to the CF one, slightly bolting them on (finger tight). Starting with the metal bars that release the tail gate, I disconnected those, removed the latches on the side, and pulled the bars out, then the lock mechanism, then the tail lights and pulled the harness through the hole, then bolted the new tail gate to the car and and tightened everything up, also aligned/adjusted it so it closed completely. </TD></TR></TABLE>
I replaced a hood from a camry and thats all I did, all the tabs, hood latch, etc... and then just put the new one on.
Old 06-22-2004, 08:34 PM
Daniel_san's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93jdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">...has anyone done this before....i have searched and nothing...let me know</TD></TR></TABLE>
no, no ones has done this befor..
btw, does anybody have a how too to wipe my *** ?
Old 06-22-2004, 10:34 PM
civic_freak's Avatar
Default Re: install a eg carbon fiber hatch? (Daniel_san)
Why do some people have to be ******** when a question is asked? I just don't get it. If you don't have anything worthwhile to contribute to the thread, then just don't respond, but if you must, at least use the spell checker so you don't look like a complete dousche bag. Have a nice day
Old 06-22-2004, 10:46 PM
H23AHybridEG's Avatar
Default Re: install a eg carbon fiber hatch? (civic_freak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_freak &raquo;</TD></TR><TR><TD CLASS="quote">dousche bag.</TD></TR></TABLE>
Maybe you should use the spell checker, too !
Old 06-22-2004, 10:47 PM
crashN2u's Avatar
When you pop open the hatch it looks confusing. All you need to do is keep track of how everything is laid out and what goes where. Once you get started it really isn't that bad. I did it on my first car by myself(I had no idea what I was doing). My only problem was keeping track of where everything went. You'll be fine, just jump in.
Old 06-23-2004, 06:15 PM
93jdmhatch's Avatar
Default Re: install a eg carbon fiber hatch? (crashN2u)
thanks..i started today..but when they made this at VIS...they didn't cut out all the holes...so now i have to cut some holes...but i know what i m dong now..
Old 06-23-2004, 09:09 PM
Default Re: install a eg carbon fiber hatch? (H23AHybridEG)
i did use spell checker dick. Maybe you are right, and the spell checker is wrong
Old 06-23-2004, 09:16 PM
stingray2772's Avatar
how much did it cost and where did you order it at? any pictures coming when its installed?
Old 06-24-2004, 07:11 AM
JDMSiGuy17's Avatar
Default Re: install a eg carbon fiber hatch? (stingray2772)
I have never had one but he sounds like he knows what he is talking about "Back when I had one, I just layed the CF tail gate on a blanket on the ground, opened the stock hatch, took off the plastic panel, and started transferring parts over one by one to the CF one, slightly bolting them on (finger tight). Starting with the metal bars that release the tail gate, I disconnected those, removed the latches on the side, and pulled the bars out, then the lock mechanism, then the tail lights and pulled the harness through the hole, then bolted the new tail gate to the car and and tightened everything up, also aligned/adjusted it so it closed completely." I would have to agree with him. Good luck with the hatch, post some pics when you figure it out.
Old 06-24-2004, 07:14 AM
Blue Sedan Crew
darkcvc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_freak &raquo;</TD></TR><TR><TD CLASS="quote">Why do some people have to be ******** when a question is asked? </TD></TR></TABLE>
<FONT SIZE="5">because we can!!</FONT>
Old 06-24-2004, 07:30 AM
civicSI23's Avatar
Default Re: install a eg carbon fiber hatch? (darkcvc)
its douche......idiot
Old 06-24-2004, 07:47 AM
Jon V's Avatar
Default Re: install a eg carbon fiber hatch? (civicSI23)
pictures?
how much does it weigh? How about the stock one?
Old 06-24-2004, 09:21 PM
93jdmhatch's Avatar
i got the hatch from http://www.rageimports.com...there are a member of honda-tech..and give us members a deal...it was $375 ...and about pics...i dont know how to do it...can some one host them for me...let me know how to post them and i will....
Old 06-24-2004, 09:26 PM
drunknbass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93jdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">i got the hatch from http://www.rageimports.com...there are a member of honda-tech..and give us members a deal...it was $375 ...and about pics...i dont know how to do it...can some one host them for me...let me know how to post them and i will....</TD></TR></TABLE>
that has to be one of the worst and most unfriendly site ive sen. i cant imagine a store relying off thatsite for sales..
Old 06-24-2004, 09:58 PM
Ajax's Avatar
Edit: Nevermind, I should read the whole post before I reply.
Old 06-24-2004, 11:46 PM
ek4hatch's Avatar
Default Re: install a eg carbon fiber hatch? (Ajax)
Ajax
LOL
Old 11-14-2013, 09:16 PM
lek9l's Avatar
You will have to modify the metal arms that move the hatch/wiper mechanism and also add washers to the hatch/wiper mechanism. You will need longer screws for the locks on the side. Lastly, you will need to do lots of drilling and possible make holes for the license plate. Was not direct bolt on like I expected but well worth it.
Old 11-14-2013, 10:35 PM
yippee-ki-yay
eHMxhACk's Avatar
9 years later...
eG.
rdt
08-02-2006 12:30 PM
duggy
01-10-2006 03:51 PM
ITR#974
10-20-2004 02:13 PM
JDMlyfestyle
04-03-2004 03:32 PM
Quick Reply: install a eg carbon fiber hatch?
