NOT ANOTHER ELECTRICAL PROBLEM
Old 12-06-2006, 03:34 PM
raphael's Avatar
Default NOT ANOTHER ELECTRICAL PROBLEM
wassup guys i bought a 96 civic from an auction a few back no that i fixed all the body damage im moving on to the electrical problems. the last owner must of been mickey mouse himself cuz the some wiring under the steering column looks a little jacked in place of a cheap *** sensitivity alarm. but the problem is the car is not starting when i turn the key all i hear is the main relay clicking fast and the all the cluster lights flashing wtf is going on? ive even tried jumping the starter with no luck. some advice pls IVE ALREADY SEARCHED AND DIDNT FIND SUFFICIENT INFO!!
Old 12-06-2006, 06:35 PM
raphael's Avatar
bump
Old 12-06-2006, 06:50 PM
Julio's Avatar
Default Re: NOT ANOTHER ELECTRICAL PROBLEM (raphael)
You have a bad starter, Or the engine is seized, if you can wrench the engine over then the starter is bad it is shorted, the selenoid is engaging but when the stater windings are energized it is shorted and causing the seloniod to loose current and open and cycle, my guess is a bad starter.
Old 12-06-2006, 07:05 PM
HRD PKR
B16B_coupe's Avatar
Default Re: NOT ANOTHER ELECTRICAL PROBLEM (Julio)
might also be a ban ground somewhere.... just replace the harness..
NAlude182
06-03-2008 01:06 PM
Chuji
11-19-2007 10:27 AM
blaxican05
09-22-2007 09:45 PM
joeg26er
06-01-2003 07:22 PM
Quick Reply: NOT ANOTHER ELECTRICAL PROBLEM
