Wrong distributer effecting ignition timing?
Old 03-21-2013, 12:24 AM
stryker gs's Avatar
Default Wrong distributer effecting ignition timing?
I recently replaced the timing belt on my civic and cant achieve corrrect ignition timing. Before changing the belt the car failed smog due to extremely high lvls of nox (all other emissions wer well within spec and co2 was almost 15%)
The ignition timing was off (8 btdc) but the distributer was fully advanced. So after checking cam timing i found it appeared to be off so i figured that would be the reason. So now the cam timin is correct and the new belt is in, however the car is actually runnin worse and proper ignition timing still cannot be achieved. I also noticed the distributor is a td31u and its my understanding that the d15b7 should have a td41u could the problem be with the distributer?
Car is a 94 civic lx sedan m/t all stock, no mods whatsoever, other than this mystery distributer
Mil is off
Any insight would be greatly appreciated! Thank you in advance!
Old 03-21-2013, 01:03 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: Wrong distributer effecting ignition timing?
First off yeah get the right distributor, the 31U is for an Accord. Then try and set the timing again.
Old 03-21-2013, 02:27 AM
slowDB7's Avatar
the distributor is definitely your problem, get the right distributor for your engine
Old 03-21-2013, 09:59 AM
stryker gs's Avatar
Thx guys! Ill give it a shot and keep you posted
Old 03-25-2013, 02:30 PM
stryker gs's Avatar
Update: so i changed to the correct distributer and set my ignition timing. After getting it smogged again it failed worse than before! :O
Emissions readings are as follows
15mph 25mph
Rpm: 1736 Rpm: 2774
Co2: 15% CO2: 15.1%
O2: .2% O2: 0.0%
Hc: 44ppm Hc: 17ppm
Co: .07% Co: .02%
No: 2022ppm No: 1238ppm
Ignition timing is 17 btdc
Based on the specs its running very efficiently just really high nox
Any ideas?
bnwbass
05-14-2016 12:37 PM
zx92027xz
08-11-2012 06:47 AM
alperx
Engine Management and Tuning
06-07-2011 05:00 AM
fogged306
05-19-2008 12:59 PM
dr_latino999
12-13-2004 02:05 PM
Quick Reply: Wrong distributer effecting ignition timing?
