New headgasket water in oil (solved)
Old 05-08-2016, 08:07 AM
sohcpower1's Avatar
Default New headgasket water in oil (solved)
Ok heres the deal my 99 single cam civic had a misfire in cylinder 2 checked compression it was low around 30psi. So i pulled the head found that cylinder exhaust valves were stuck open! Replaced valves put new headgasket new head bolts torqued properly. Car started right up ran relly good but i noticed white smoke coming from the exhaust manifold. Shut the car down seen the oil was milky inside the valve cover. Ran the car again and it looks like the white smoke is coming from the converter aoat like heat sheild is smoking? Not sure but my guess is its just seaping out of the cat somehow. Any ideas?
Old 05-08-2016, 08:50 AM
Former User's Avatar
Default re: New headgasket water in oil (solved)
Likely a bad head gasket install, unless the block is cracked.
Old 05-08-2016, 09:02 AM
sohcpower1's Avatar
Was kinda thinking that. I never changed the oil when i took tbe head off and was told coolant could get into oil that way
Old 05-08-2016, 09:46 AM
Change the oil.
Old 05-08-2016, 11:08 AM
White_EG1's Avatar
You gotta drain coolant and oil so there's no chance either will mix
parton84
12-16-2013 06:36 AM
JdmJah
16
02-19-2013 06:42 PM
4g4dcruisin
01-05-2013 12:46 AM
em1effekt
18
07-06-2011 04:18 PM
Nextelbuddy
05-03-2005 06:21 AM
Quick Reply: New headgasket water in oil (solved)
