found this today....blown head gasket?..
Old 06-27-2011, 09:02 PM
em1effekt's Avatar
Default found this today....blown head gasket?..
i was looking at my motor today and this is what i found...
oil between the head and the block...noticed a little under the distributor
thought it wasnt a big deal but then behind my exhaust manifold there seems to be alot of oil comming down from the top...wich would be between the head and block....
car over heats when i take it to high rpms sometimes not always...but i was thinking that could be a seperate problem...no white smoke
motor is a b20vtec turbo..everything is new...
what do you guys think??
under dizzy near transmission side..
behind exhaust manifold (headers)
Old 06-27-2011, 09:36 PM
Linked's Avatar
Default Re: found this today....blown head gasket?..
oil cant escape to the outside of the engine because of a blown headgasket
when the HG blows its normally between a cylinder and the coolant jackets, in which instance oil can get into the coolant, or coolant can get into the combustion chamber and blow steam out the exhaust.
try cleaning around the head in all the nooks and crannies and let the oil drip back down, that's how you'll find your leak
common leaks are the dizzy o-ring, vtec solenoid gasket, valve cover gasket
Old 06-28-2011, 09:52 AM
motegicivic's Avatar
That is what I thought, I have the same problem and had a honda tech look at it, he seems to think it is the head gasket. Basically he said the head gasket can leak coolant and oil, I always thought just coolant.
I had it happening for years without issues, I have to check the oil once a week to watch it, but just keep adding oil and still no issues, no smoke, no mixing of coolant and oil.
Old 06-28-2011, 08:21 PM
Nickeg9Ej1's Avatar
you may have a problem with the head lifting at high rpms, are you using head studs or stock bolts?
Old 06-28-2011, 08:32 PM
pata's Avatar
clean it up real good all around.
If you haven't, replace your cam seal and dizzy o ring. I would remove the vtec soleniod and put some gasket maker on it and reinstall it. Should take care of that side of the leaks
Old 06-28-2011, 10:22 PM
Corksil's Avatar
i have a similar wet spot on my motor around the dizzy-side of the head.
distributor o-rings are known points of failure - car overheats, o-ring gets hard and crispy, oil drips and runs onto heater hose right below, hose breaks down, then more problems. I have odyssey vans and so far 5/6 have needed the o-ring replaced.
i will be tracking down my oil source in a few weeks but here is my plan...
oil/filter change
just changed vtak solenoid to be safe
distributor o-ring
new head-gasket w/headstuds
will be using parts cleaner to clean ALL oil and grime around headgasket
watch for highest point of oil visible
keep us posted i have a b20v with similar issues. i would love to figure this out.
Old 06-28-2011, 11:03 PM
apexi_rsx's Avatar
definitely could just be an oil leak or worn out gasket that needs replaced. did the car overheat at all is that why your asking about your head gasket. if its running normal temp then there is no blown head gasket or is anything wrong with it but a leaky gasket.
Old 06-29-2011, 12:39 AM
em1effekt's Avatar
i am using arp head studs...
at first i thought it might come from the top...like the valve cover...or dizzy..but then i noticed the oil behind the exhaust manifold..wich made me think it was the head gasket...
yes it over heats and random times...i let it sit for a while and then open the radiator add a bit of water and then its back to normal....but i am thinking i have a small leak somewhere because it does not over hear every time...
Old 06-29-2011, 09:07 AM
apexi_rsx's Avatar
u can buy a dye to put in your coolant and use a black light at night and search for ur leak.
Old 06-29-2011, 03:40 PM
em1effekt's Avatar
okay so today i had my brother rev the motor while i cheked to see if any oil would come out from anywhere...i was not able to find anything..but i also see oil on my oil pan where the hose coming from the turbo connects to the fitting on the pan...and also around the pipe where my dip stick goes into...
im getting really frustrated taking it into the shop tomorow..see if they can help...
when i reved the motor...at high rpms i see smoke coming out from the valve on the valve cover...is that normal?...it comes out for like a second and goes away...
Old 06-29-2011, 06:18 PM
Nickeg9Ej1's Avatar
do you have a properly working pcv system? reason I ask is I worked 5 years at jiffy lube seen the worst of the worst there, completely blocked pcv systems will cause everywhere to leak, also smoke will pour out of dipstick tubes and oil caps etc... not saying its that but its easy enough to check
Old 06-29-2011, 06:22 PM
apexi_rsx's Avatar
yes that little bit of white smoke coming from the valve cover vent hose is normal in a boosted vehicle. if he is boosted he should be using a open catch can system with a breather and not have a pcv check valve should be removed.when boosted leaving the stock pcv valve int will cause the bottom end to build up pressure and make the rings blow out and cause a bunch of blow by. im kind of confused now. the engine your posting up is not boosted and your last post seems to lead toward that your motor is boosted. please inform us if it is or not.
Old 06-29-2011, 06:26 PM
Slacker93eg's Avatar
Does it sputter at all under high RPM? Or seem to lose power?
Old 06-29-2011, 10:28 PM
em1effekt's Avatar
it doesnt sputter or anything at all..it runs how it has always ran...very good...
the motor is boosted..i put a pic of the motor that is not boosted just to show the little valve on the valve cover i was talking about..
Old 06-30-2011, 06:01 PM
em1effekt's Avatar
took it to the shop where i usually take my car to....
the guy looked at it and said it could be the line that conects to my turbo..that runs near my exhaust manifold...
but that he will check it out..so i wont know until maybe tomorow or the weekend..
Old 07-01-2011, 03:58 PM
em1effekt's Avatar
so my mechanic said the leak is coming from the fittings on the lines going to the turbo... and the distributor o ring...hopefully when its taken care of it solves my problem..
Old 07-01-2011, 07:46 PM
95EG2's Avatar
leaking head gasket maybe not blown... ill would check VC gasket common problem ppl mistake a leak from a head gasket and actually a valve cover gasket
Old 07-01-2011, 09:05 PM
apexi_rsx's Avatar
OP already had it checked out by a mechanic. he said its a fitting going to the turbo (probably the feed line) and the distributor O ring.
Old 07-06-2011, 04:18 PM
em1effekt's Avatar
^^^^ yes i had the car back....since saturday..and so far no more leaks anywhere...
thanks for the help guys..
98civc123
23
09-08-2021 08:14 PM
JdmJah
16
02-19-2013 06:42 PM
4g4dcruisin
01-05-2013 12:46 AM
IVI
03-29-2004 04:55 PM
Halo
08-12-2002 06:27 PM
Quick Reply: found this today....blown head gasket?..
