Need quick help on wiring air horn to relay.
Old 04-22-2007, 07:48 PM
SiYouLater's Avatar
Default Need quick help on wiring air horn to relay.
Well I'm trying to install some air horns. Just need some help on wiring the relay. I want to run it to a momentary switch with 2 prongs. Which part of the relay do I wire it to?
Old 04-22-2007, 08:09 PM
RyCeRoCkeTz's Avatar
Default Re: Need quick help on wiring air horn to relay. (SiYouLater)
Old 04-22-2007, 08:14 PM
flipsyde's Avatar
air horn on a civic??
Old 04-22-2007, 08:15 PM
iceman7329's Avatar
Default Re: (flipsyde)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipsyde &raquo;</TD></TR><TR><TD CLASS="quote">air horn on a civic??</TD></TR></TABLE>
Yep, Ive got a 3 horn setup on mine. Great for ******* who pull out in front of you or cut you off.
Old 04-22-2007, 08:30 PM
SiYouLater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipsyde &raquo;</TD></TR><TR><TD CLASS="quote">air horn on a civic??</TD></TR></TABLE> Yes, thats what I said.
Old 04-23-2007, 08:48 AM
SiYouLater's Avatar
anyone?
Old 04-23-2007, 10:40 AM
93egsir's Avatar
take the factory horn wires and run one to pin 84 and the other to pin 85 that will turn the relay on when you press the stock horn button now take a power lead from the battery and run it to the 86 terminal on the relay. and terminal 87 is now the power feed to the horn compressor. The other side of the compressor gets a good ground and honk away
Old 04-23-2007, 11:03 AM
wrx-killer-Sti-eater's Avatar
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (93egsir)
^^^^^^^ what kind of relay are you using?
Old 04-23-2007, 11:33 AM
SiYouLater's Avatar
I'm trying to wire it to a separate switch and not the stock horn.
Old 04-24-2007, 04:57 AM
93egsir's Avatar
Default Re: (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">^^^^^^^ what kind of relay are you using?</TD></TR></TABLE>
a standard bosch single throw relay
Old 04-24-2007, 04:58 AM
93egsir's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater &raquo;</TD></TR><TR><TD CLASS="quote">I'm trying to wire it to a separate switch and not the stock horn. </TD></TR></TABLE>
what kind of switch and how many post are on the switch
Old 04-24-2007, 05:17 AM
SiYouLater's Avatar
Default Re: Need quick help on wiring air horn to relay. (93egsir)
Basic momentary switch with 2 prongs.
Old 04-24-2007, 05:00 PM
SiYouLater's Avatar
Would this work?
30 - fused power (to battery)
87 - air horn +
85 - Ground -
86 - switch
And then ground the switch. Does that look right?
Modified by SiYouLater at 6:24 PM 4/24/2007
Old 04-24-2007, 05:02 PM
iceman7329's Avatar
Dude the12volt.com
Old 04-25-2007, 06:59 AM
93egsir's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater &raquo;</TD></TR><TR><TD CLASS="quote">Would this work?
87 - air horn +
85 - Ground -
86 - switch
Modified by SiYouLater at 6:24 PM 4/24/2007</TD></TR></TABLE>
the 86 term would need power. you need power (+) on 85 and negative(-) on 86 or vise fersa. either way will work.
but I would since you have a fused power sorce for the worns and the relay, run fused power to both 30 and 85 then run a ground trigger from the momentary switch to 86. then 87 is the out to the air horns
Old 04-25-2007, 10:59 AM
SiYouLater's Avatar
Old 04-26-2007, 02:30 PM
SiYouLater's Avatar
what do you guys think of the diagram?
moorevisual
08-25-2009 04:55 PM
street_ride14
06-01-2008 07:29 AM
SiYouLater
10
04-12-2006 09:58 PM
Zubz
Audio / Security / Video
11-19-2002 09:21 PM
Zubz
09-03-2002 09:49 AM
Quick Reply: Need quick help on wiring air horn to relay.
