Need Help!
Old 03-09-2009, 07:49 PM
91greenbeast's Avatar
Default Need Help!
I have a 93 civic with a b16. Sometimes the check engine light comes on but not alot. I hit some bumps and the car sputters and jerks a bit. Sometimes it runs fine but then sometimes I give it at least half throttle, it sputters. Any help would be greatly apprectiated.
Old 03-09-2009, 07:57 PM
PEK*EGGEM's Avatar
Default Re: Need Help!
What cel code is the ecu throwen?
Old 03-09-2009, 08:00 PM
Not sure. I can't find anything to check it with. But I do remember that there is a dent in the gas tank.
Old 03-09-2009, 08:11 PM
CivicSpoon's Avatar
There are 2 stickies at the top of the '92-'00 Civic subforum, that explain how to check what code you're throwing.
Old 03-09-2009, 08:14 PM
Swansen's Avatar
Honestly guy, you should find out what the check light is for. Call around, i'm sure some place will bring up the codes for free, or maybe like $30 or something.
Old 03-09-2009, 08:31 PM
But the would the dent in the gas tank cause it to sputter also? My friend works in Orr Honda superstore as a mechanic and he just told to push the dent out with a board. Isn't there some kind of paint or some type of liner in the tank that will come off?
Old 03-09-2009, 08:35 PM
Swansen's Avatar
No reason that dent will cause any problems, unless its contacting the fuel pump. As far as the board thing goes, you would have to drop the tank and take out the fuel pump to get at it.
Old 03-09-2009, 08:59 PM
Maybe im not doing it right but i just tried to check the cel but the light just stays on.
Old 03-09-2009, 09:12 PM
Global Moderator
Jimmy's Avatar
https://honda-tech.com/forums/showthread.php?t=2407755
OEMJDM
Honda Civic (2001 - 2005)
09-23-2012 09:03 PM
coasttime
08-05-2009 03:53 PM
drkns
07-21-2006 09:11 PM
FD3S_11b
11-11-2005 10:04 AM
SuPeRITR
03-18-2003 06:02 PM
Quick Reply: Need Help!
