ls build
Old 10-06-2006, 09:47 PM
ek4ferrio's Avatar
Default ls build
is doing a ls build more stressful then just getting a b series with vtec should the build be done profesionally or what cause im confused if i should jus get a gsr or jus go and build my ls to ls vtec if any input thx
Old 10-06-2006, 09:49 PM
HT White Ops
Eran's Avatar
What?
An LS is no different to build than any other honda motor. It has a crankshaft, four rods, and four pistons, and an interferance head. Just like any other B.
Old 10-06-2006, 10:13 PM
nighttrain33's Avatar
Default Re: ls build (ek4ferrio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4ferrio &raquo;</TD></TR><TR><TD CLASS="quote">is doing a ls build more stressful then just getting a b series with vtec should the build be done profesionally or what cause im confused if i should jus get a gsr or jus go and build my ls to ls vtec if any input thx </TD></TR></TABLE>
Will you be doing this yourself? If so, then you either need to read up a lot, or just have it done professionally. There is more work to doing an LS/vtec than a normal B-swap, only because you need to drill for the vtec, but both are pretty involved if you don't know what you are doing.
If you search LS/vtec, you will find just about any info you could possibly ask for.
Also, <FONT COLOR="red">here</FONT> is info on swapping a B-series.
-Shane
Old 10-06-2006, 10:14 PM
Default Re: ls build (nighttrain33)
*Edit* I just realized that you already have an LS, but if you don't know what you are doing, it is still a bit of work.
-Shane
zenon8890
12-22-2005 10:31 PM
JDM-Rota
08-05-2005 08:35 PM
slammedtegls
09-15-2004 12:58 PM
integra racr04
08-17-2004 01:25 AM
97teggLS
06-01-2004 08:20 AM
Quick Reply: ls build
