'94 civic with B20 swap wont start.
Old 02-11-2011, 12:39 PM
Jonathannx2's Avatar
Default '94 civic with B20 swap wont start.
I have a 1994 Civic coupe B20 motor.
My car has had a problem where it would be hard to go into gear sometimes and I would have to force it in.
This morning my car wouldn't start. The radio would turn on and the fuel pump will prime but the car won't crank or start.
My clutch reservoir or what ever it is called has fluid.
My clutch master cylinder has some fluid around it like gunk.
Is it my clutch master cylinder that has gone bad? Or something else?
Thanks for the help.
Old 02-11-2011, 03:57 PM
TheJunBuilt's Avatar
Default Re: Car won't start
?? can u disable to clutch so u can start it without pushing the clutch in .. can u pop start it . does it crank at all .?
Old 02-11-2011, 04:37 PM
It usually starts without having to have the clutch pressed in. I tried starting it a while ago and it started.
Old 02-12-2011, 12:18 AM
Default Re: '94 civic with B20 swap wont start.
bump
Old 02-12-2011, 05:45 AM
foo fighters's Avatar
may be your clutch return spring inside the tranny, behind the throw out bearing. or your starter switch behind the clutch peddle.
Old 02-14-2011, 01:09 AM
white99ekcoupe
11
07-24-2014 12:56 AM
civicpark81
11-01-2007 08:18 AM
anteater
12-31-2005 09:31 PM
TEG777
08-10-2005 10:24 AM
sparq
02-01-2003 09:54 AM
Quick Reply: '94 civic with B20 swap wont start.
