idle surge after y8 I'm swap
Old 08-27-2016, 06:57 PM
Srt.ej1's Avatar
Default idle surge after y8 I'm swap
hey guys. I swapped the y8 intake manifold onto my y7. used the y7 injectors and fuel rail. y8 intake with y7 throttle rotor. new gaskets. I haven't been able to find a diagram of all the hoses and lines but according to what I know and the threads I used everything is in the right spot. from what I understand there is an iacv on the throttle body and now one on the back of the y8 I'm. I have the one the throttle body plugged in and no plug onto the I'm one. I looped the bottom of the useless iacv and have no sensor plugged in. when I start the car it revs super high and stays there. please
Old 08-27-2016, 06:59 PM
Srt.ej1's Avatar
Default Re: idle surge after y8 I'm swap
help
Old 08-27-2016, 08:15 PM
mk378's Avatar
Car details?
You need to get the IACV hooked up to the ECU. The only version to use a 2-wire IACV is the manual EX. If you have an automatic you need the automatic EX manifold with three-wire IACV. If the car is manual you need to swap the ECU and move some wires to convert to a 2-wire system.
Old 08-27-2016, 08:32 PM
Srt.ej1's Avatar
1999 hatch 5speed.
your saying the sensor on the back of the IM needs to be hooked up as well as the one on the throttle body. and since my car is standard I need a new computer to run the y8 IM
Old 08-27-2016, 08:48 PM
Srt.ej1's Avatar
some people just block off the whole iacv on the back of the manifold so why should it matter if I plug it in or not
Old 08-28-2016, 08:09 AM
FactionR's Avatar
What year y8 manifold is it 96-98 or 99-00?
Old 08-28-2016, 08:53 AM
Srt.ej1's Avatar
I don't know how to check but I did read about the air Injection holes so Im about to check if those are on mine and if so I will jb weld them. or stack gaskets?
Old 08-28-2016, 09:26 AM
Srt.ej1's Avatar
Old 08-28-2016, 11:44 AM
FactionR's Avatar
Air injection y8 mani need help - D-series.org
This thread has a pic of the injection nipple located between injectors/runners 2/3. easy to tell if you have it or not. If you do and its not capped, there is your major vacuum leak. That thread had another link to deleting the port if necessary.
montanacivic
12
10-31-2015 02:13 AM
EKMIKEY27
12-07-2010 11:11 AM
TurboGoKart
09-30-2009 02:53 PM
triple5soul4165
02-20-2009 03:20 PM
thedanny88
12-09-2008 12:53 PM
Quick Reply: idle surge after y8 I'm swap
