How to remove steering wheel with hub?
Old 03-08-2004, 05:59 PM
SIR Spooner's Avatar
Default How to remove steering wheel with hub?
How do I remove the steering wheel off the car? Thanks
Old 03-08-2004, 07:28 PM
Default Re: How to remove steering wheel with hub? (92SIvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92SIvic &raquo;</TD></TR><TR><TD CLASS="quote">use a puller.</TD></TR></TABLE>
Thanks for the replay.
What is a puller? Thanks
Old 03-08-2004, 07:45 PM
TurboBumblBee's Avatar
Default Re: How to remove steering wheel with hub? (j d m)
remove the airbag its a hex key forget the size, disconnect the srs and cruise and horn connecters, get a 19mm on a 3/8 w/ an expentension and follow lefty loosey, righty tighty, and then once the bolt is removed pull on the steering wheel and it will come off w/ no problem..
Old 03-08-2004, 07:47 PM
Ricey McRicerton's Avatar
Default Re: How to remove steering wheel with hub? (hybrid94Si)
Don't forget to disconnect the battery....or the airbag could go off in your face.
Old 03-08-2004, 07:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget to disconnect the battery....or the airbag could go off in your face. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid94Si &raquo;</TD></TR><TR><TD CLASS="quote">remove the airbag its a hex key forget the size, disconnect the srs and cruise and horn connecters, get a 19mm on a 3/8 w/ an expentension and follow lefty loosey, righty tighty, and then once the bolt is removed pull on the steering wheel and it will come off w/ no problem..</TD></TR></TABLE>
The problem I have is the hub is still on, but i got the steering wheel off. So it looks like a hard cyclinder is stuck on there.
EK9Tune
07-11-2007 11:26 AM
jivi
Honda Civic (2001 - 2005)
06-30-2007 11:13 AM
moonboy01
11-16-2005 09:02 AM
Nextelbuddy
05-20-2005 07:21 PM
socalep3
01-27-2004 07:57 PM
Quick Reply: How to remove steering wheel with hub?
