How to install your own aftermarket horn on EK!!!
Old 06-02-2006, 05:15 PM
lcjarrett's Avatar
Default How to install your own aftermarket horn on EK!!!
Here we go...Sorry if this isn't a good write up but i am trying to help all the EK owners that want to use there horn with an aftermarket steering wheel...
Tools:
Screwdriver
Wire Cutter
Electrical Tape
Piece of metal (6 1/2 inches long)
2 Pieces Speaker Wire (6 inches)
Double Sided Connector
Prong Connector
1st : Located the horn button under the steering column it looks like this...
I cut mine before I made this post but anyways you can see that there are three wires that come out of the horn button(teal wire with black line, teal wire with red line and a blue wire with a silver line). The horn wire is the blue wire so double sided connector, connect it to a piece of speaker wire and to will look like this...
Now that you connected the horn wire to the speaker wire you have to get that metal piece that you needed and here is the tricky part...You have bolt up this metal piece to the steering column and make sure that the metal piece is touching the brass part of the hub which is in the back of the hub. Which should look like this...Front View
Top View...
Rear View...
When you bolt on that metal piece it's time to get that horn wire with the connector and bolt that up to the screw that you used to bolt up the metal piece. Which should look like this...
After you bolt that screw on now it's the easy part...That wire that comes with the hub is going to connect to the prong that is on the botttom of the quick release. Now with the other piece of wire and the prong connector this will be the ground wire that will connect to the other prong on the bottom of the Quick Release. The ground can be bolted the steering wheel nut...Which should look like this...
Now from the Quick Release you have wires in there also. Make sure that you wire the Quick Release RIGHT. The ground to the ground and the power wire which is the horn wire the the horn wire...Then from the Quick Release wire it up to the aftermarket horn....Then kazaam...honk honk!!!!!! HAHA
I hope this post helps out all you EK owners...
Old 06-02-2006, 06:26 PM
ekVtecPower's Avatar
Default Re: How to install your own aftermarket horn on EK!!! (lcjarrett)
good write up..
Old 06-02-2006, 06:59 PM
VRD^sam's Avatar
Default Re: How to install your own aftermarket horn on EK!!! (ekVtecPower)
use marco next time you take pictures
Old 06-02-2006, 07:04 PM
lcjarrett's Avatar
Default Re: How to install your own aftermarket horn on EK!!! (..::ferio::..)
what the F*** is Marco?
Old 06-02-2006, 07:22 PM
jp8900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lcjarrett &raquo;</TD></TR><TR><TD CLASS="quote">what the F*** is Marco?</TD></TR></TABLE>
He meant mAcro.... its a camera setting where u can take super up close pics in clear quality........(haha laymans terms)
Old 06-02-2006, 08:17 PM
SuperSi's Avatar
Default Re: How to install your own aftermarket horn on EK!!! (jp8900)
Marco hahahahha Thanks for the write up.
Old 09-22-2006, 04:50 AM
viskii420's Avatar
nice write up
Old 09-29-2006, 03:44 PM
turbob18si's Avatar
the only question I have is after you remove your cable reel how do you get the signalst to turn off automatically ek specific
Old 09-29-2006, 03:52 PM
BlueIntegraBoy's Avatar
Default Re: How to install your own aftermarket horn on EK!!! (turbob18si)
I need to get my horn working again.
Old 09-29-2006, 04:02 PM
NMZ
NMZ's Avatar
Default Re: How to install your own aftermarket horn on EK!!! (BlueIntegraBoy)
this is confusing man
does that wire stick out like that all the time
Old 10-09-2006, 10:33 AM
Jdmglenn's Avatar
Default Re: How to install your own aftermarket horn on EK!!! (dontgivafuk)
just one wire goes to the metal strip, and the other two go to the backside of the cover. The wire doesnt really stick out cuz your ign. plastics cover it all
jiggatone
02-10-2008 12:48 PM
dylokjai
14
10-13-2006 01:10 PM
SuperSi
26
06-02-2006 05:18 PM
Chris y0!
03-22-2003 08:30 PM
Quick Reply: How to install your own aftermarket horn on EK!!!
