How do you?
cute little bastard
Re: (PrettyFastRide)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyFastRide »</TD></TR><TR><TD CLASS="quote">I got how to change it but... HOw do you bleed it </TD></TR></TABLE>
transmission fluid and clutch fluid are two different things. You don't bleed the transmission fluid, but you bleed the clutch fluid lines.
Have a buddy help you do it.
have a friend press/hold the pedal down once but don't pump it. Then you open the bleeder. Its on the transmission left of the header area. Close the bleeder and have your friend lift up the pedal. Repeat until all the air is out
Re: (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote"> transmission fluid and clutch fluid are two different things. You don't bleed the transmission fluid, but you bleed the clutch fluid lines</TD></TR></TABLE>
Apocolipse269
10
09-03-2004 08:06 AM
