How do I make a d16z6 VTEC head work on my d15b8 engine?
Old 10-27-2010, 01:19 AM
EGKevin209's Avatar
Icon6 How do I make a d16z6 VTEC head work on my d15b8 engine?
i have a d15b8 in my hatch, i wanted to slap a d16z6 head on it. what do i need to make this vtec head work with this bottom block. thanks
Old 10-27-2010, 10:28 AM
CivicSpoon's Avatar
Default Re: How do I make a d16z6 VTEC head work on my d15b8 engine?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-d15-sohc-vtec-mini-me-massive-write-up-56k-goodbye-554053/
There are literally hundreds of places to find the info. Just do a search on here or google (for "mini-me civic" or mini-me honda") if that link doesn't provide enough info. It will be the same thing as a vtec head on a D15B7 (the work you'll have to do).
Old 10-27-2010, 12:50 PM
PHANTOM MENACE
24TEN's Avatar
^This is correct above, but there are a couple of things that actually are different (at least they were different on my B8). First, make sure it has PM3 pistons. It's often said that early B8 engines still had 8 valve specific pistons in them while later B8 engines had standard DX pistons so you may or may not have additional work depending on your motor. Second, B8 specific injectors run at a much lower fuel rate than basically all other injectors so if you had planned on reusing your injectors you better get another set. Finally, the water pipe is different on the B8 (at least mine was) in that it has one outlet instead of two. I have diagrams/pics I can show you if needed.
Old 10-27-2010, 01:55 PM
Seagull Management
94EG8's Avatar
No D15B8 used 2 valve pistons from what I can find, I checked part numbers one time before, every year used the same pistons as a D15B7.
Old 10-27-2010, 02:09 PM
Technical Hero
HondaPartsHero's Avatar
13010-P03-010
Part number for 92-95 DX and CX every year
Old 01-18-2011, 09:45 AM
uncl3j0n's Avatar
was not aware that the b8 had a different water pipe...
Integra303
07-09-2009 04:40 PM
litleblackhatch
05-08-2006 01:24 PM
ljonestopsavings
07-21-2005 05:08 PM
autoEXturbo
11-27-2002 05:23 AM
Quick Reply: How do I make a d16z6 VTEC head work on my d15b8 engine?
