how can i tell if i jump a tooth
Old 11-15-2005, 04:14 PM
lv6l's Avatar
Default how can i tell if i jump a tooth
i have a 94 civic cx. all stock. i think my timing belt jump a tooth, i want to know how can i tell if it jump or not by looking at it?? thanks.
Old 11-15-2005, 04:22 PM
LVB18Civic's Avatar
Default Re: how can i tell if i jump a tooth (lv6l)
Turn the motor over until the white mark on the crank pulley lines up with the mark on the lower timing cover. Then remove the upper timing cover and check to see if the upper marks are lined up. If any of the marks are off you know that it jumped.
Old 11-15-2005, 05:10 PM
evade this honda's Avatar
sucks if it did.
Old 11-15-2005, 07:30 PM
lv6l's Avatar
my mark color on my crank pully are faded out. i see 5 lines. l l l l l. in the sets of 3 lines, the middle line is RED.
Old 11-15-2005, 07:39 PM
Soccerking3000's Avatar
Default Re: (lv6l)
it'll run like complete **** and the timing will be way off. But as stated before make sure the marks on the crank line up and the 2 lines on the cam gear are parallel to the head
Old 11-15-2005, 07:56 PM
lv6l's Avatar
i have 5 lines, do i line up the crank pully's middle line of the 3 sets? (same line i lined up when i do my timing?)
Old 11-16-2005, 12:04 PM
lv6l's Avatar
bump
Old 11-17-2005, 12:33 PM
butt_munch024's Avatar
check to see if number1 piston is at tdc with#1 at top you will see if crank lines up with cam
lv6l
11-17-2005 04:41 PM
Power Rev Racing
08-15-2005 04:45 AM
Kirt Porter
10-08-2004 09:10 PM
JONBLAZE55555
11-27-2003 09:09 AM
ScottEK
13
09-25-2002 08:23 PM
Quick Reply: how can i tell if i jump a tooth
