Honda Civic with B20 swap cranks but won't start
Old 05-31-2011, 03:33 PM
Jonathannx2's Avatar
Default Honda Civic with B20 swap cranks but won't start
1994 Honda Civic. Cranks but doesn't start. Fuel pump primes gets a red spark not blue.
Will the weak spark sill be enough to start car?
What should I change?
Thanks in advance.
Old 05-31-2011, 05:20 PM
civichxtreme2's Avatar
Default Re: Honda Civic with B20 swap cranks but won't start
Probably not enough spark. Start with plugs and wires. Wires are far more important than people think, If that doesnt help try the disttributor
Old 05-31-2011, 05:34 PM
Former User's Avatar
Sounds like a bad coil inside the distributor. Resistance test it.
Old 05-31-2011, 10:05 PM
I already got it tested at Autozone. Tested at 10 so I got a new one. Car fired up then died after idle. Spark is still red.
Old 06-01-2011, 02:17 AM
LoLoCivic's Avatar
Do you have any Cel? (check engine light)
Old 06-01-2011, 02:54 PM
No. Fuel pump is priming too.
Old 06-01-2011, 03:10 PM
slammed4dreg's Avatar
i say if you can swap out distributors from one of ur buddys working car and see if it starts. cuz most likley its gonna be your distributor.
Old 06-01-2011, 04:58 PM
Alright thanks. Only car I can test one off of is a GSR. Would the vtec distributor work? I know the bolt mounting locations are different.
Old 06-02-2011, 09:48 PM
Update. Got a new distributor. Didn't spark so I changed to coil in it. Sparked but didn't start.
Eventually my friend's brother in law started to just crank the car and floor the gas and eventually it just started. Don't know why but it did. Any ideas why?
Travis Davidson
07-25-2017 07:11 PM
PSHuertas
12-02-2013 06:25 PM
honvic
12-04-2011 07:27 AM
tommy.
10
05-30-2010 06:15 PM
majinx4
06-02-2006 06:42 PM
Quick Reply: Honda Civic with B20 swap cranks but won't start
