Headlight - one doesn't work
Problem is with passenger headlight. The bulb in question is the one in the smaller housing on stock eg lights. It used to work. Car sat in my backyard for 1.5 years. Doesn't work now.
Already swapped bulbs with the respective driver side one. Bulb not the problem. Engine bay and underdash fuses all good. I think it's a wiring issue but not really sure where to start with the multimeter. I also just learned how to use a multimeter in preparation to diagnose this issue.
Just looking for some direction I guess...
Re: Headlight - one doesn't work
most likely its gonna be wiring. sometimes when a car sits that long, moisture gets in the wiring, and in the winter the moisture freezes damaging the wire.
Check and see if the bulb plug is corroded. Seems odd the wiring would be changed unless a rodent got in there and nawed something up.
accord ex
03-13-2003 05:55 PM
