HELP !!Car wont turn off after taking the key out.
Old 06-16-2002, 02:50 PM
IdotheSHOCKER's Avatar
Default HELP !!Car wont turn off after taking the key out.
Okay so I finish my rebuild and reinstall my engine.
Now when I hook up the battery the car acts as if the engine is on. without the key being in the ignition.
Then when I start the car it runs but after turning the key off it won't turn off? I have to pull the distributor wire in order to get the sucker to shut down.
HELP !!
Old 06-16-2002, 03:53 PM
WHATS VTEC's Avatar
Default Re: HELP !!Car wont turn off after taking the key out. (EGB18hatch)
hahahahaha, its like a remot start and a turbo timer, dno't know how to help you there, but good luck with it
Old 06-16-2002, 03:58 PM
EG8R's Avatar
Default Re: HELP !!Car wont turn off after taking the key out. (low93ex)
I'm not a pro at this. Ignition wire not hooked up properly??
Old 06-16-2002, 04:53 PM
thashadow's Avatar
Default Re: HELP !!Car wont turn off after taking the key out. (mr. skelly)
yeah check ignition wires....thats definatly a wierd problem, can't remember hearing about something like that
Old 06-16-2002, 05:32 PM
Default Re: HELP !!Car wont turn off after taking the key out. (thashadow)
Okay go ahead and kick me after I'm done kicking myself.
I forgot that I installed a clock into my CX. I as dumb as it sounds put the clock power harness into the hazard button switch.
This causing the ignition to act like it did.
Weird simple things like this can cause such huge problems.
So if you ever have an engine running and it wont stop even when the key is pulled out a wise thing to do is unplug the distributor wire.
And recheck all your electrical connections.
89CRXSi_24
01-21-2012 10:03 PM
misternguyen
17
11-15-2008 11:45 AM
Frankie324
01-25-2003 06:03 PM
IdotheSHOCKER
06-16-2002 08:10 PM
Jonathan
09-23-2001 09:36 PM
Quick Reply: HELP !!Car wont turn off after taking the key out.
