Help with 93 civic speedometer. (not a vss)
Old 09-02-2010, 04:12 PM
Vtec Civic 93's Avatar
Default Help with 93 civic speedometer. (not a vss)
Alright i've got a 93 honda civic ex, 5 speed transmission.
I'm having issues with the speedometer. Randomly one day while driving on the highway the speedometer stopped working. Once in a great great while it'll read for a few seconds then just go right back to 0. I swapped in a different VSS and it still didn't work. I sprayed electric cleaner in the plugs and it still doesn't work.
Anyone have any other suggestions??
Old 09-02-2010, 04:45 PM
Former User's Avatar
Default Re: Help with 93 civic speedometer. (not a vss)
Is code 17 (VSS circuit) thrown?
Old 09-02-2010, 06:15 PM
It is thrown when you de-acellerate in gear. Say you drop from 3k to 2k rpm, it will throw the code.
Old 09-02-2010, 06:19 PM
Check the VSS signal wire for a short. It's a Yel/Wht wire at the VSS plug and changes to a Yel/Blu wire as it runs to the ECU, speedo, and cruise control.
Old 09-02-2010, 06:21 PM
So check it from the VSS to the ECU first, then continue on?
Car does not have cruise control anymore.
Old 09-02-2010, 06:26 PM
Start here: Unplug only the VSS connector and test the Yel/Wht wire terminal in the connector for resistance (Ohms) to body ground using a digital multimeter.
Maybe the short is in the disconnected cc wire.
Old 09-02-2010, 06:29 PM
Will try that as soon as i can, and when i probe the terminal/ground the other, what should it read on the mm?
Old 09-02-2010, 06:32 PM
If there's no short, then you should measure high resistance, probably less than 10 Ohms.
Old 09-02-2010, 06:45 PM
Hello Bart's Avatar
i have seen millions of times where the pins at the vss plug get coroded, and does not make contact... the tab on the pins will fall off... thats usually where i start..
Old 09-02-2010, 08:15 PM
if that's the case, where can i get a new plug/wires??
as far as the cc wire, i believe the wires were just cut and left.
Old 09-02-2010, 08:52 PM
Hello Bart's Avatar
just go to pick a part and swipe a plug with enough wire to solder back together.. i guess the cruise control one would be as easy as repairing what is cut...
joeydd3
06-16-2018 04:30 PM
steve56
10-26-2012 05:18 AM
PGHRich
11
09-10-2010 05:18 PM
ejvtec
11-22-2009 11:41 AM
yg_klan
09-15-2009 01:15 PM
Quick Reply: Help with 93 civic speedometer. (not a vss)
