Fuel pump not priming...
Old 02-21-2010, 04:26 PM
GSR_hatch936's Avatar
Default Fuel pump not priming...
Ok i changed my oem fuel pump out of my eg hatch cuz it wasnt priming soo i figured if i was gonna buy a fuel pump i might as well buy a walbro fuel pump so i did... Well now with the walbro its still isnt priming, So what i did is wire it direct to the battery and started priming!! But then hooked it up to the clip from the car and turn the key and it wont prime?... So i changed the ecu 2 times, also changed the main relay with one i bought used for a junk yard and then changed the main relay with the relay my wife has on here car which is working perfectly!! and it still will not prime! im stumped and cant figure it out.. I also have a Clifford alarm system which i completely took it off and put it back on to try to figure it out but jus cant get it to prime... I need help guy please tell me im missing something to fix this promblem
Old 02-21-2010, 05:18 PM
xero_xero's Avatar
Default Re: Fuel pump not priming...
check the ecu fuse, it will be (in orientation to the car) rear passenger fuse (i believe a 15 or 20)
Old 02-21-2010, 05:21 PM
Yea the 15 fuse under the hood i have checked it too...
Old 02-21-2010, 08:44 PM
TTT
Old 02-25-2010, 10:11 AM
jdmeg6honda's Avatar
if i were you i get a digital volt meter and test if any power is coming out of the main relay on mines it was yellow with green strip that has power coming from the main relay but no power to the fuel pump so i ghetto rig it from the main relay to 1 of the fuel power wire next 2 the drvier seat and it should be like 11. sum or 12 volt coming on when you turn on position 2 but not starting it .it will have power on for like 10 second.
SPUNKYMUNKY
11
03-27-2015 03:58 PM
snzh22
08-08-2007 04:53 PM
frost_0ne
09-13-2005 01:02 PM
Quick Reply: Fuel pump not priming...
