fuel pump / no voltage?
Old 03-26-2014, 02:49 PM
civic28's Avatar
Icon2 fuel pump / no voltage?
I do not have 12V at the fuel pump connector. My fuel main relay is good, my fuel pump is good. (tested it directly with 12V)
So my problem is from the fuel main relay to the fuel pump connector.
Has anyone have had a short from the front compartment (fuel main relay) to the rear (fuel pump) connector wiring??
These tests are with the ignition key on.
There is a "box" looking grey connector at the fuel pump that has only 6V power with the ignition key on.
My 99 Civic won't start anymore. Its worked yesterday, came out in the morning to go to work, turns over, but won't start. I don't have fuel.
I will be checking if there is any continuity from the main fuel relay connector pin terminals 5 & 7 to the 2 terminals on the fuel pump connector. I just don't have a long enough jumper wire to do this. I'm going to buy one.
Any ideas??
Old 03-26-2014, 04:18 PM
Former User's Avatar
Default Re: fuel pump / no voltage?
Test fuses 44 and 13.
Dxvid
05-02-2019 02:05 PM
2ndthtsurplace
04-10-2011 11:15 AM
ksbenjamin44
06-25-2009 05:22 PM
whitehf
08-06-2006 01:22 PM
bigbacon2
07-31-2005 05:34 PM
Quick Reply: fuel pump / no voltage?
