freshly built gsr Swap wont start (no spark)
Old 08-31-2009, 08:50 AM
GSR_EJ2's Avatar
Icon3 freshly built gsr Swap wont start (no spark)
Ok i put the new engine in connected everything like it should but it still wont start. Its getting fuel but no spark. i put in a new ignition control module for the dizzy and still nothing, i have replaced the msd blaster coil and still no start. when i check with my test light in the dizzy i get power to everything even my ecu imput wire on the ICM, but no spark. When i hook my spark tester up from the msd coil to the coil wire on the msd dizzy cap and ground my testlight to the ecu imput on the ICM it will spark but other than that nothing. it really has me puzzzled because when i pulled the old GSR swap it ran fine.
Old 08-31-2009, 08:56 AM
delsolproblems's Avatar
Default Re: freshly built gsr Swap wont start (no spark)
Check the grounds.
Old 08-31-2009, 09:12 AM
GSR_EJ2's Avatar
Originally Posted by delsolproblems
Check the grounds.
checked all grounds and are fine
Old 08-31-2009, 11:15 AM
Jimster480's Avatar
so your fuel pump is priming? It could be a bad ECU. Your saying there is power to the cap but not to the spark plug wires?
Old 08-31-2009, 12:07 PM
GSR_EJ2's Avatar
fuel pump is priming got a 255 lph bbk hard not to hear it, ive already tested the ecu theory tried 3 different ecu's 2 p72's and a custom tuned p28 for the engine in it now, theres power to the dizzy none to the plugs and the coil wont fire only time i got spark from it was when i hooked a spark tester from the coil to the coil wire and put the test light to the ECU imput in the ignition control module only then i would see spark
Old 08-31-2009, 12:49 PM
Jimster480's Avatar
So did you change the ICM?
And you said you tried a different coil. Is it possible that both coils are bad?
Old 08-31-2009, 09:58 PM
So you're getting spark when the tester is connected to the coil wire and grounded to the ICM but you're getting nothing when grounded to the valve cover. That would have to mean a bad ground. If the grounds are fine then you can't be right about getting nothing when connected in every way other than what you described.
Old 08-31-2009, 10:00 PM
Master Detailer
98civdx's Avatar
coil? they go out queit often. try switching the dizzy with a different one.
Old 08-31-2009, 10:17 PM
SWISS_MISS's Avatar
sounds like the wire from the ecu to the icm is broken inside or a bad connection since when you hook up the test light it works. the test light will work like a new wire. try replacing that wire and see what happens.
Old 08-31-2009, 10:23 PM
:::SIRll_EJ1:::'s Avatar
post up if u get it to start soon, im curious to see what happened
Old 09-01-2009, 03:04 PM
GSR_EJ2's Avatar
yep bought a new ICM and put it in also the coil im using is a brand new msd SS blaster coil since im running the msd sci.
Old 09-01-2009, 03:12 PM
GSR_EJ2's Avatar
Honestly ive been doing these swaps for years now its the first time ive ever had a problem with one starting. The car already had the GSR swap when i took it out and built it I put everything back like it was when it was pulled. all grounds are in stock locations i rechecked when you said.. last thing i know is to try a stock distributor and uninstall the msd
Old 09-01-2009, 03:13 PM
GSR_EJ2's Avatar
its a good possibility will check that thanks 4 the reply
Old 09-01-2009, 03:19 PM
GSR_EJ2's Avatar
Will do il keep throwing money into it until it does in way too deep on this project to get my money back out of it
Old 09-02-2009, 07:42 AM
Jimster480's Avatar
that really sucks. Have you checked continuity through all the wires? maybe one of the wires got torn in the harness during the swap.
Old 09-03-2009, 06:39 AM
GSR_EJ2's Avatar
Could be im willing to try anything at this point.
Old 09-03-2009, 07:02 AM
Former User's Avatar
As mentioned, use your multimeter to check for lack of continuity or a short in the Yel/Grn wire running between the ICM and ECU.
turbo gsr
05-12-2007 12:06 PM
AznBlueBoy
09-08-2006 08:21 PM
rice a roni
05-23-2006 10:22 AM
scUba-stEve
12-18-2004 10:28 AM
AccordDX89
05-18-2004 10:47 AM
Quick Reply: freshly built gsr Swap wont start (no spark)
