Which ecu for my setup?
Old 04-12-2015, 05:15 PM
FeRReTTi's Avatar
Default Which ecu for my setup?
Alright, so I have a 97 Del Sol S. It currently has an OBD2 ECU that says "37820-P1Z-A02" on it. I'm assuming its what came in the car stock. Now, the previous owner swapped in a D16Z6 block, which I know is OBD1. It also has the head from a D16Y8 which I know is OBD2. So my question is, should I be using the P28 ecu with an OBD1 conversion harness, or the P2P ecu which is native to the D16Y8? Or would it not matter at all? I've read that some people had issues running the P28 on a D16Y8 motor, but thats not exactly what my setup is, so I was wondering what you guys thought. Thanks!
Old 04-12-2015, 05:22 PM
Fish Twig
tony_2018's Avatar
Default Re: Which ecu for my setup?
find a obd2a p2p, do the ckf bypass trick and you should be good.
Old 04-12-2015, 05:23 PM
Technical Hero
HondaPartsHero's Avatar
Honestly find a 96-97 P28 OBD2A ECU. That way with emissions testing you'll connect to the scanner as well (OBD1 ECU's will not). The P2P may cause you to throw some fuel pressure sensor codes as it does in many peoples swapped Civics.
Old 04-12-2015, 06:05 PM
FeRReTTi's Avatar
I don't need to worry with emissions as my car is over 15 years old so they don't plug it in. Aren't those ECU's really hard to find?
Old 04-12-2015, 06:19 PM
Fish Twig
tony_2018's Avatar
they had such a thing? Or are you talking about hondata's obd2a p28.
edit: yes, they had such a thing.
Old 04-13-2015, 02:07 AM
Technical Hero
I wouldn't call them rare but they aren't as common as P2P's. You could do an OBD1 P28 but I'm not sure if anyone makes a legit P2P basemap.
Old 04-13-2015, 05:31 PM
GDD's Resident Derp
W95civicEXcoupe's Avatar
Rob?
Welcome to HT! :D
Old 04-20-2015, 09:35 PM
FeRReTTi's Avatar
Originally Posted by W95civicEXcoupe
Rob?
Welcome to HT! :D
Who is Rob?!
KodSol
23
01-02-2012 10:40 AM
j_mee_5
03-21-2011 09:14 AM
madsci
11
03-10-2010 08:45 PM
Site123
Engine Management and Tuning
03-13-2009 11:44 AM
MR_EJ8
09-06-2005 10:28 AM
Quick Reply: Which ecu for my setup?
