D16z6 running on two cylinders after rebuild.
Old 06-17-2005, 10:47 AM
O16581724 5 2 5's Avatar
Default D16z6 running on two cylinders after rebuild.
I'm not positive if my timing belt is on the correct teeth, reguardless, if i skip it some teeth, it runs bad still, of course some teeth much worse than others. When removing the number 1 and number 2 spark plugs, the car idles up a little and runs the same, when removing 3 and 4, the car nearly dies.
Sup wit dat?
Old 06-20-2005, 09:53 AM
Default Re: D16z6 running on two cylinders after rebuild. (x O 16581 72452 5 x)
Running the injectors in the right sequence and having the firing order correct makes a big difference.
Old 06-20-2005, 10:27 AM
b204dr's Avatar
what do you mean injectors in the right sequence- ? i have a nearly same problem are is running on 3 ! my number 3 is down and i can take the plug out and it runs the same- remove the plug and its covered with oil mixed with gas like its not burning the fuel but it is getting spark so it makes no sense
Old 06-20-2005, 11:55 AM
Default Re: (b204dr)
Check your firing order, number 1 is the point towards the intake manifold (Haynes said it was the buttom point), firing sequence is 1 3 4 2.
I brought my injector harness in from the passenger side insted of the driver's side, i had them installed completely backwards.
Old 05-09-2006, 07:19 PM
I want a CRX tattoed on my butt
PINKS's Avatar
Default Re: (O16581724 5 2 5)
So whats the actual firing order? Can you make a diagram?
ko12upted
17
12-09-2012 07:08 AM
boarding2008
04-07-2012 01:32 PM
stephen_civic98
02-23-2010 09:50 AM
sirdeus
11-01-2007 08:22 PM
Quick Reply: D16z6 running on two cylinders after rebuild.
