D16Y7 Swap Questions
Old 03-05-2012, 05:09 PM
Randolph's Avatar
Icon2 D16Y7 Swap Questions
Ok so I am putting in a D16Y7 motor with transmission into my 1996 Civic LX four door. I am using everything OBD2a but the distributor which is OBD1. I attached the picture of a step down harness I was given and was told I could "splice" it into the distributor and plug it up to my OBD2a harness. Now that is ghetto and I am better off getting a OBD2a distributor of course, but could I get away with doing this for now? And would I throw any CEL codes for doing so?
Also. The exhaust manifold that's on the motor has 1 oxygen sensor on it. From what I remember, these manifolds are suppose to have 2 for the D16Y7. I assume the ECU (P2E) will look for the 2nd one and throw a code for that as well?
The intake manifold on the D16Y7 motor is from a D16Z6. I remember there was something I had to change on the harness but can't remember exactly what it was. I think it was a 2 -> 3 wire conversion or something of the like.
Thanks for any help.
Old 03-05-2012, 05:16 PM
talonboy1991's Avatar
Default Re: D16Y7 Swap Questions
That obd1- obd2 conversion harness shouldnt need any splicing. As per the o2 sensors the y7 was goofy and had the cat in the exhaust manifold you need that manifold and a primary and secondary o2 sensor or you will have a cel for the o2 or you can run a obd2- obd1 conversion harness and run a p06 (obd1) ecu and then you can run just the primary o2 sensor
Old 03-05-2012, 05:18 PM
Randolph's Avatar
thanks for the response! yeah i can't plug it into the OBD1 distributor i have now....it has the same plugs as the picture i posted! unless its odb2 -> odb1 step down i have?
Old 03-05-2012, 05:28 PM
canadaek's Avatar
why not just get a y7 dizzy ? and if your using the y7 ecu you need to keep the 3 wire iacv if your using a manual y8 intake you will need to use the y7 t/body and block off the iacv port on the back of the intake .
Old 03-05-2012, 05:43 PM
hmm im not sure then? the obd1 should be the 2 plugs and the one plug should be the obd2 part lol i dont know why anyone would run a obd2 dizzy in an obd1 car....
Old 03-13-2012, 01:00 PM
Randolph's Avatar
EDIT: shortly after posting this, i got it running.
becauseracecar8
02-24-2016 07:10 PM
sir.rexington
15
10-20-2010 01:48 PM
DelSlowmo
03-13-2010 12:54 AM
Hoppa
05-12-2006 01:16 PM
dw.VTEC
08-22-2005 12:09 PM
Quick Reply: D16Y7 Swap Questions
