D16B5???
Old 03-01-2011, 06:19 AM
92lxsleeper's Avatar
Default D16B5???
D16B5
(Identical to the D16Y5. Main differences are Pistons, Rods, Camshaft, Head Gasket, Intake Manifold, and Exhaust Manifold are PDN rather than P2M)
* Found in:
o 1998-2000 Honda Civic GX
+ Displacement : 1,590 cc (97 cu in)
+ Bore and Stroke : 75 × 90 mm (3.0 × 3.5 in)
+ Rod Length : 137 mm
+ Compression : 12.5:1
+ Combustion Chamber Volume : 32.8 cc per cylinder
+ Power : 185hp @ 8500 rpm
+ Torque : 160ft·lbf (? kg/m, ? Nm) @ rpm
+ Valvetrain : SOHC VTEC-E
+ VTEC Switchover : 5700 rpm
+ Fuel Control : OBD-2 MPFI
+ ECU Code: PDN-A02
does this really exist? found it on wiki.
Old 03-01-2011, 06:21 AM
The Grumpiest
grumblemarc's Avatar
Default Re: D16B5???
http://www.youtube.com/watch?v=jB_kv7dbRLk
http://www.google.com/search?q=D16B5...ient=firefox-a
Apparently they do.
You should search harder.
Old 03-01-2011, 06:25 AM
speedooo's Avatar
8500rpm? 160lb/ft torque? sohc?
Old 03-01-2011, 06:26 AM
sorry im on my phone with edge service, so its a bit slow lol.
Old 03-01-2011, 06:48 AM
The Grumpiest
That's what I was thinking. That's what happens when anyone can "contribute" to a wiki.
D16Y5
* VTEC-E
* Found in :
o 1996-2000 Honda Civic HX
o 1996 Honda Civic EX(sedan Peruvian version)
+ Rod/Stroke : 1.52
+ Compression : 9.4:1
+ Power : 115 hp (85.8 kW, 117 ps) @ 5600 rpm
+ Torque : 104 ft·lbf (14.4 kg/m, 141 Nm) @ 4500 rpm
+ Valvetrain : SOHC VTEC-E (4 valves per cylinder)
+ Head Code : P2J
o 1996-2000 Honda Civic VTI
+ Compression : ?:?
+ Power : 127 hp (94.7 kW, 129 ps) @ 5800 rpm
+ Torque :111 ft·lbf (? kg/m, ? Nm) @ ? rpm
+ Valvetrain : SOHC VTEC-E(4 valves per cylinder)
+ Head Code : P2J
+ ECU Code : P2N
+ Piston Code : P2MY
Old 03-01-2011, 08:28 AM
mik101's Avatar
Seriously guys?
It says Civic GX, not HX.
The numbers the OP posted are surely wrong, but no it's not supposed to be the vtec-e variant (D16Y5) from the HX.
A quick google search verifies the GX is the compressed natural gas variant.
Sold 1998+ and each civic model since has had a variation of the engine converted to run on CNG (1.6L 1.7L 1.8L).
http://en.wikipedia.org/wiki/Honda_Civic_GX
Old 03-01-2011, 10:52 AM
The Grumpiest
Seriously guys what? I know the HP/redline must be wrong. That's why depending on wiki information to be correct is not a good practice.
civic_turbo_EJ9
05-06-2014 02:44 PM
j0keefe21
14
01-27-2010 08:44 AM
nate24740
Honda Civic (2001 - 2005)
22
05-18-2009 10:24 AM
LSXFEIND
02-26-2009 08:36 AM
efjones9
12-05-2008 08:19 AM
Quick Reply: D16B5???
