D15b, starts and fires up but will not stay idle
Old 06-22-2009, 08:32 AM
atarigamer01's Avatar
Default D15b, starts and fires up but will not stay idle
For about the past week or so it's been having an idle issue. It starts and fires but as soon as I let go off the key it just dies. No error codes, been running great except for this. Lately Ive been lucky and itll stay at idle after I start it up but no luck today. It never died on me while driving, but sometimes the rpm would slightly go up and down and I could hear my fuel pump doing the same. Any clues or suggestions?
Old 06-22-2009, 08:51 AM
ek-g6's Avatar
Default Re: D15b, starts and fires up but will not stay idle
sounds like your idle air control valve(iacv). Use some brake or carb cleaner, if not your iacv try adjusting the idle bleeder screw.
Old 06-22-2009, 04:24 PM
Post Re: D15b, starts and fires up but will not stay idle
I was thinking that, but I also forgot to mention that when I turn the key I don't hear it click the the first or second time. Especially the second time, I don't see the battery or cel, and I don't hear the fuel pump prime. But it starts and then when I let off the key it dies. I was thinking is it the main relay possibly?
Old 06-22-2009, 06:57 PM
92lxsleeper's Avatar
you got it!
Old 06-22-2009, 07:40 PM
Former User's Avatar
Your ignition switch may be kaput in position ON(II).
Old 06-22-2009, 10:12 PM
How would I go about fixing the ignition switch?
Old 06-22-2009, 10:29 PM
First test the switch with a multimeter:
Old 06-23-2009, 09:17 AM
Oh thanks! I'm pretty sure it's the main relay though, but who knows. I don't hear or feel it clicking at all. It's probably only starting up due to the remainder of gas thats left over in the rail, I'm guessing. I'm going to long beach this weekend so I hope I can get it fixed by then; cross your fingers!
Old 06-23-2009, 09:21 AM
A bad main relay does not explain the lack of a CEL and battery light. A bad ignition switch would. It's pretty easy to test with a multimeter.
Old 06-23-2009, 10:59 AM
dE.fUsEd's Avatar
Main Relay will not throw a code or a battery light. It just won't work after it gets warm.
Ask me how I know?
Old 06-23-2009, 12:56 PM
Ask me how I know?
The point is that when the key is turned to ON(II), the CEL should go on for 2 seconds and the battery light should remain on. These normal events did not happen (see post 3), hinting at a problem with the ignition switch.
Old 06-23-2009, 04:56 PM
I just got the main relay out from under the dash. At first I held it while starting it and no clicks but then I kind of shook it around and it started to then click, fuel pump primes, but still no dice. I felt a click before and after the pump and then a third when it started. It starts up and kicks over but once my hand is off the key it just goes off again. Aaagh, I dunno what to do!
Old 06-24-2009, 08:14 AM
I'm gonna go with the ignition switch. I saw another forum where a dude had the exact same symptoms as mine. It ended up just being a dirty connector. We'll see what happens!
Old 06-24-2009, 10:25 AM
Hey, I got it started and running. The part that connects to the housing, I had to clean some of the little burn marks (it looks like) off. Put it back together and started right up and stayed running! I might buy another oem one though and replace it just for peace of mind cause it looks like someone already messed with it (the wiring).
raverx3m
Engine Management and Tuning
03-31-2015 04:43 PM
Koko4
10-09-2014 06:34 AM
b18cisbetter
12-08-2009 06:04 AM
iblaine
06-11-2008 02:57 PM
garyc17
10-21-2007 09:48 PM
Quick Reply: D15b, starts and fires up but will not stay idle
