Code 41 on a 1994 Civic CX
Old 06-22-2010, 01:48 PM
calvin924597's Avatar
Default Code 41 on a 1994 Civic CX
I've got a 1994 Civic CX hatchback, and I'm getting a code 41 CEL, which to my understanding is the Oxygen Sensor Heater. However, CX's have the 1 wire o2 sensor, which is not heated. I replaced the oxygen sensor with a Denso one yesterday, and I'm still getting code 41. What else could it be?
Old 06-22-2010, 01:52 PM
Former User's Avatar
Default Re: Code 41 on a 1994 Civic CX
Do you have a D15B7 engine? If so, your ECU is looking for a 4-wire O2 sensor.
Old 06-22-2010, 02:01 PM
Nope, I've got a D15B8 8 valve. The ECU was never replaced, I've got maintenence records from the previous owner goign back 6-7 years.
Old 06-22-2010, 02:03 PM
You seem to have the wrong ECU. Post the numbers on the ECU. You should have a P05.
Old 06-22-2010, 08:04 PM
Just went out and checked. I've definitely got a P05... I dont know what the problem could be. A short in a wire somewhere?
Old 06-22-2010, 08:07 PM
Are you reading the CEL code correctly? Post a video.
Old 06-22-2010, 08:43 PM
I don't have a digital camera that takes video (mine is too old) but it is clearly four long flashes and then one short one.
Old 06-23-2010, 06:43 AM
You may have an ECU problem because a P05 should not throw code 41.
Old 06-23-2010, 09:02 AM
When I short the 2 wires to check the code, the SRS light starts flashing as well.What does that mean? I searched and couldn't find anything on that.
A bad ECU might make sense. I've had this stupid undiagnosable misfire at idle even after pretty much everything has been replaced, and now this code 41 thing.
Old 06-23-2010, 09:57 AM
Jumping the service connector retrieves not only CEL codes but also SRS (air bag) codes, which blink from the SRS light. You have a fault in your SRS circuit.
Old 06-23-2010, 10:03 AM
JDM_SOHC's Avatar
A P05 is an OBD1 CX ECU so it should throw the same codes as any other OBD1 ecu..
Is it the stock ECU..?? How long have you had the code for..??
Old 06-23-2010, 03:49 PM
The P05 ECU looks for a one wire O2 sensor that lacks a heater element. Therefore, it would not throw code 41 for a faulty heater element.
Old 06-23-2010, 08:00 PM
Yep, its the stock ECU. I've had the code for as long as I've owned the car (month and a half) and the guy before me had it at least since last february.
ruben6805
12-17-2014 06:27 AM
Tobi Vil
04-19-2014 06:42 PM
mikej94civex
11
05-22-2010 01:40 PM
SpoolnByYou
15
03-26-2006 08:43 AM
Gimp
03-04-2004 02:14 PM
Quick Reply: Code 41 on a 1994 Civic CX
