Clutch squeaks-annoying
Old 06-10-2008, 07:17 AM
ultima.maniac's Avatar
Default Clutch squeaks-annoying
What are some ways to stop this? It's been squeaking for a couple days now whenever I press the pedal in and I already find it irritating.
Old 06-10-2008, 07:29 AM
blaze the chemi's Avatar
Default Re: Clutch squeaks-annoying (ultima.maniac)
is it the clutch (coming from the engine bay) or is it sqeaking near the clutch cylinder just above your pedal inside the cabin? You may need some moly-grease for the pedal assembly in the cabin area.
Old 06-10-2008, 07:43 AM
andoxviii's Avatar
Mine squeaks as well, but only sometimes and it comes from the engine bay. Any insight on this would be great!
Old 06-10-2008, 08:04 AM
JdelMsolG's Avatar
Default Re: (andoxviii)
it could possibly be the throwout bearing. sometimes they start with a faint squeak then turn into a nasty noise.
Old 06-10-2008, 08:33 AM
Kendo88's Avatar
Default Re: (JdelMsolG)
i had the same problem, and found out that it was the throwout bearing. My clutch was in need of replacement so i got a new clutch kit and included was the throwout bearing. Ever since i haven't heard the squeaking sound.
Old 06-10-2008, 11:04 AM
mechanix619's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdelMsolG &raquo;</TD></TR><TR><TD CLASS="quote">it could possibly be the throwout bearing. sometimes they start with a faint squeak then turn into a nasty noise.</TD></TR></TABLE>
x3 on the throwout bearing. Too bad the transmission has to come off just to change one little part but it's a great opportunity to replace the clutch and possibly the rear main seal (just for good measure).
Old 06-10-2008, 06:09 PM
Default Re: Clutch squeaks-annoying (blaze the chemi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaze the chemi &raquo;</TD></TR><TR><TD CLASS="quote">is it the clutch (coming from the engine bay) or is it sqeaking near the clutch cylinder just above your pedal inside the cabin? You may need some moly-grease for the pedal assembly in the cabin area.</TD></TR></TABLE>
Engine bay
I looked around on the web for about an hour and found some people fixed the squeak by removing the slave cylinder (if thats correct, the guide was a little confusing) and lubricating the ball joint with lithium grease so I guess I'll give that a try.
Nataku
09-18-2010 06:22 PM
YAH YAH
06-11-2007 09:59 AM
EliTe 93Lude
07-27-2006 06:58 AM
VTECgsr00
02-07-2006 09:30 AM
Beezle
10-02-2004 10:25 AM
Quick Reply: Clutch squeaks-annoying
