CKf bypass trick safe?
I'm getting error code p1337 on my 99 si with the b16a2 engine and stock ECU, will doing the CKF bypass trick have any negative side effects? Also, will it pass smog in CA? Thank you.
Re: CKf bypass trick safe?
It should be, I have to do this as well soon just lazy. You can always just install a usdm oil pump and wire it too just a bit pricey.
