Check Engine Light - Code 420 - Need a New Cat
Old 08-18-2006, 06:49 AM
steveo2000em1's Avatar
Default Check Engine Light - Code 420 - Need a New Cat
First off car is 2000 Si
Any suggestions on a replacement cat? My CEL is on and I got the code which is 420 (catalyst efficiency below threshold). From my research it's most likely the cat or o2 sensor (or sensors)
Thanks to all
Old 08-18-2006, 08:22 AM
ludakrishna420's Avatar
Default Re: Check Engine Light - Code 420 - Need a New Cat (steveo2000em1)
The CAT is covered under the USA 8 year / 80000 mile warranty. EVERY car company has to abide by this law. So if your car is less than 8 years old or less than 80kmiles , which ever comes first, the stealership has to cover it under its warranty and replace it for free or they can face federal trouble. If they refuse, threaten to contact American Honda and say that the dealership refuses to honor this warranty.
Just make sure that your cat still has the heat shield and everything. Also, make sure that it has not been messed with.
here's the quote word for word about the warranty.
"8 YEAR 80,000 MILE FEDERAL EMISSION DEFECT AND PERFORMANCE WARRANTY
# Covers repair or replacement of the following original Honda major emissions control components that cause the vehicle to fail to conform to an applicable EPA approved Inspection/Maintenance Program: 1) Catalytic Converter 2) Engine Control Module 3) Onboard Emissions Diagnostic Device (OBDII)
# Other EPA (Environmental Protection Agency) emissions warranty parts are covered under the 5 years / 60,000 mile New Vehicle Limited Warranty."
Old 08-18-2006, 10:21 AM
Thanks for the reply but I have 120,000 miles on my car so the warranty doesn't apply to me.
Old 08-18-2006, 10:36 AM
EE_Chris's Avatar
Default Re: (steveo2000em1)
If you've got a 120k on the secondary O2 sensor, I'd start there as a probable cause before suspecting the catalytic converter.
Old 08-18-2006, 10:52 AM
If I were to switch the car to OBD1 (I'm thinking of getting a p28 ecu) do you still even need the secondary o2 sensor? I'm pretty sure you don't because there's only 1 o2 sensor then right?
Old 08-18-2006, 11:01 AM
Former Moderator
B18C5-EH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveo2000em1 &raquo;</TD></TR><TR><TD CLASS="quote">If I were to switch the car to OBD1 (I'm thinking of getting a p28 ecu) do you still even need the secondary o2 sensor? I'm pretty sure you don't because there's only 1 o2 sensor then right?</TD></TR></TABLE>
Correct, and OBD1 doesn't throw bullshit cat. efficiency low codes either.
Biggest question:
Do you live in a state with emissions testing?
Old 08-18-2006, 03:07 PM
code 420 is for the CAT not the O2 sensor. Granted it wouldn't be a bad idea to replace the sensor, i would more be interested in changing the cat. Before i found out about the law, i just kept driving with my bad cat. Then one day i started to hear really messed up noises. Turned out to be the cat and it sounded like my engine had a bolt in it and was hitting everything in there.
seriot
21
05-12-2013 02:45 PM
jc007i
01-23-2012 12:29 AM
denmick
01-04-2007 05:07 PM
ironryder
06-03-2006 09:09 PM
onyx00
04-16-2002 01:00 PM
Quick Reply: Check Engine Light - Code 420 - Need a New Cat
