Check engine light on
Old 12-16-2004, 02:47 PM
importdreamer's Avatar
Default Check engine light on
I was driving my car (98 civic EX) home last night and the check engine light came on about a block down the road. Everything was fine(no sputter no overheating no running too lean or too rich) I pulled over and the speedometer said I was still going 20 mph. Then, after no explosions or gremlins laughing at me, I started leaving again. Speedometer said I was still doing 20, but was not at all, I was closer to 40. My friend said I should just turn off the car while I was driving and the ecu would reset. I put it in neutral and turned it off then turned it back on. The check engine light was still on but at least the speedometer started working. Nothing is wrong other than the light being on so should i just pull the number 3 fuse by the engine or should i check it out?
Old 12-16-2004, 02:56 PM
GdmLaz's Avatar
Default Re: Check engine light on (importdreamer)
2 reset the ecu you have to taKE OFF the negative terminal off the battery for lyk 20 seconds and then plug it back in that will reset it not just turnin it on
Old 12-16-2004, 03:00 PM
_Cyclone_'s Avatar
Pull the code out of the computer first. You'll probably find a Code 17- VSS Vehicle Speed Sensor. Hondas are known for having these go bad.
Old 12-16-2004, 03:11 PM
Default Re: Check engine light on (Slammed92hbonN20)
im not too worried about reseting the ecu ( but thanks to you i actually no how when the time comes )im more worried about if that sound like a legitamit problem or just a fluke. It is really ******* cold up here and i wonder if that did it.
Old 12-16-2004, 03:13 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 &raquo;</TD></TR><TR><TD CLASS="quote">2 reset the ecu you have to taKE OFF the negative terminal off the battery for lyk 20 seconds and then plug it back in that will reset it not just turnin it on</TD></TR></TABLE>
its actually better to just remove the ECU fuse in the engine bay fuse box
that way you dont loose your radio presets
Old 12-16-2004, 03:16 PM
huntarrr's Avatar
pull the code from the ECU, then get back to us.
Old 12-16-2004, 03:19 PM
Default Re: Check engine light on (CycloneBlue_1.6EL)
But the speedometer worked today (I think) it seemed pretty acurate.
Old 12-16-2004, 03:31 PM
all right i got a friend that works at a shop I'll check it out tommorrow while we put his "poor man's type-r" swap in his Si thanks
Old 12-16-2004, 08:55 PM
GdmLaz's Avatar
probably ur vss is about to go bad like mentioned before they go bad often specially on cars that are lyk 13 years old lol
Old 12-16-2004, 10:17 PM
my lil hatchie's Avatar
check engine light no good
Old 12-16-2004, 10:31 PM
dantastic's Avatar
Default Re: Check engine light on (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">its actually better to just remove the ECU fuse in the engine bay fuse box
that way you dont loose your radio presets </TD></TR></TABLE>
have you done this b4? it doesn't reset your ECU. you need to pull the 7.5A "Back up" fuse. if you have a factory stereo, you will need to reset your stereo presets, clock, and you'll need your radio's security code. i have an aftermarket deck, and i didn't have to reset my stations.
Old 12-17-2004, 07:07 AM
Default Re: Check engine light on (dantastic)
this morning the check engine light just turned off and the the speedometer sat a 20 mph again. I stopped and turned it off and everything is fine now. WTF?!?!?!
Old 12-17-2004, 07:14 AM
huntarrr's Avatar
loose wire.
check the code when it comes back on!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 12-17-2004, 07:24 AM
Default Re: Check engine light on (vsm98civic)
I'll check it out at the shop tonight.
pang07
08-06-2013 05:11 PM
Danny Sihapanya
12-15-2012 06:45 PM
ericrcan
11-24-2012 07:54 PM
dohmahklan714
10-21-2006 08:43 PM
Quick Reply: Check engine light on
