Need Help With Swapping Auto Tranny To 5 spd
Old 06-30-2010, 07:43 PM
jes77's Avatar
Icon2 Need Help With Swapping Auto Tranny To 5 spd
i have a 93 civic coupe with a d15b7 ive decided to do the mini me swap with a y8 head and since i have to get a new ecu i want to use the p28 which means i have to go from auto tranny to 5spd. can anyone help with what all i will need to do this and how to go about it?
Old 06-30-2010, 07:57 PM
apexi_rsx's Avatar
Default Re: Need Help With Swapping Auto Tranny To 5 spd
linkage,ecu,pedals,tranny,clutch, slave cylinder and master cylinder with resevoir. you will need to do some fabricating and wiring as well
Old 06-30-2010, 09:19 PM
jdmcarboy1990's Avatar
you will also need the steel line that runs from your slave cylinder to your tranny and you need a five speed brake pedal i did this on my 94 hatch and that steel line is a pain. you will also need to run a wire from the back up switch on the tranny to the tail lights i have heard of doing this a different way but idk.
Old 07-01-2010, 07:21 AM
apexi_rsx's Avatar
you can just wire the reverse wires to the old wiring where the auto shifter was... thiers many write ups... search!
Old 07-01-2010, 07:44 AM
EatMyVTEC :]'s Avatar
x2
Old 07-01-2010, 02:25 PM
jes77's Avatar
what kind of fabricating and wiring?
Old 07-01-2010, 02:29 PM
dmeconitas's Avatar
Just as a note, just because you change the ecu does not mean you have to go 5 speed.
Old 07-01-2010, 02:34 PM
apexi_rsx's Avatar
cutting the hole out out for the new shifter to come through the floor board . your gonna need a piece of sheet metal. wiring your gonna have to wire the lock up switch and reverse lights. its all easy to do as i said before google it or use the search its been covered over a thousand times
Old 07-01-2010, 02:43 PM
HAMOTORSPORTS's Avatar
And you'll need this auto to manual conversion mount..
http://www.hamotorsports.com/egamhmount.html
/shameless plug
Old 07-01-2010, 04:50 PM
apexi_rsx's Avatar
i used my stock mounts and it worked perfectly.. no need for that mount... some say u need the tranny bracket but the auto one worked fine for me
Old 07-01-2010, 04:58 PM
Linked's Avatar
from what i read, you dont NEED to go 5spd if your swapping to a p28, there are auto p28 ecus
although i would advise you swap to manual for the benefit, its not a necessity if you jsut want to do a mini-me swap
Old 07-02-2010, 02:25 AM
Seagull Management
94EG8's Avatar
You need the mount on a '92 - '95 Civic/'94 - '01 Integra. If you got it to work your engine is sitting crooked and you will have major axle issues.
Frosty93
06-01-2011 11:47 AM
avy288
03-29-2007 10:55 AM
hxslowness
02-14-2006 04:43 AM
dailygirl
27
06-17-2004 10:10 PM
Quick Reply: Need Help With Swapping Auto Tranny To 5 spd
