A/C Compressor pulley frozen
Old 04-30-2013, 03:10 PM
Drazz's Avatar
Default A/C Compressor pulley frozen
I recently noticed my A/c Compressor belt was mysteriously gone so I decided to replace it. After doing so I start the engine, which was a lil hard to turn over due to the pulley, and theres this loud constant squealing. So I turn the engine off before even looking at it cuz it just did not sound too pleasant. I reach through the wheel well and touch the belt and its red-hot. I'm assuming my pulley is frozen. Do I have to order a whole new A/c compressor? A new pulley? Please help and thank you.
Old 04-30-2013, 03:35 PM
goldsy's Avatar
Default Re: A/C Compressor pulley frozen
Take the belt off and see if you can spin the compressor by hand. Chances are it's the bearing in the tensioner pulley that's seized not the compressor. If so you can just replace that bearing. It's between the compressor and the crank pulley. It's simple to change. 1 nut!
What year is your Civic?
Old 04-30-2013, 07:53 PM
Drazz's Avatar
Thank you I'll check that out. Its a '98.
Old 05-01-2013, 04:44 AM
sleepyaccord96's Avatar
compressor clutch May be locked up
Old 05-01-2013, 05:13 AM
nealnanoHX's Avatar
Yeah it is worth checking the tensioner pulley but I bet you compressor is locked up. If that is the case you need to do an AC kit which includes the compressor, receiver drier and expansion valve as well as you need to flush the condenser. You may get lucky and just have a locked up compressor bearing or clutch if that is the case then just a new compressor will fix it.
Old 05-01-2013, 06:57 AM
Drazz's Avatar
Ok so it could be the bearing, the clutch, or the compressor itself? How do I tell?
Crobran
02-10-2017 07:55 AM
zcmotor
10-01-2013 08:15 PM
redacura
05-26-2008 03:57 PM
sporkcrx
08-11-2004 10:30 PM
Quick Reply: A/C Compressor pulley frozen
