broke manifold stud, need advise please..
Old 07-25-2009, 02:33 AM
robbys89's Avatar
Default broke manifold stud, need advise please..
ok so a while ago i put a new exhaust manifold on the car (93 civic b16a) and i broke 2 studs, their still sticking out from the block just not enough to pass the manifold, can these be screwed out or would i have too re-tap them?
Old 07-25-2009, 08:02 AM
B-outAteam's Avatar
Default Re: broke manifold stud, need advise please..
so ur saying the two studs are sticking out right. get some vise grips and take them out and put new ones in. if u cant grap it wit the vise grips then gota drill and tap
Old 07-25-2009, 08:12 AM
honda.lioness's Avatar
The exhaust manifold studs breaking is pretty common. If the vise grips do not work, a cam style stud remover is definitely worth a try. This tool worked like a charm when a couple of these studs broke on my 91 Civic a few years ago. Its studs required the 8 mm stud remover. See
http://www.amazon.com/Dr-Stud-Remove...8538445&sr=8-1
http://www.costplustools.com/Sunex-S...et_p_5425.html and
http://www.redhillsupply.com/KDT41760.htm.
Autozone or NAPA may have these, too. I was able to buy mine individually for around $15 on Ebay a few years ago.
Harbor Freight has a cheap (under $5) stud remover tool that may work fine too.
excivicboy96
15
07-08-2009 03:07 PM
xEnderx
02-04-2006 07:36 AM
JDubya
11-01-2003 07:38 AM
Kimbo
04-22-2003 06:13 AM
Quick Reply: broke manifold stud, need advise please..
