Exhaust Manifold Studs?
Old 04-10-2007, 01:44 PM
excivicboy96's Avatar
Default Exhaust Manifold Studs?
How hard are the Exhaust Manifold Studs to take out? I rounded off one of the bolts and wanted to see how hard it is to replace the stud as I'll probably have to replace it.
Old 04-10-2007, 01:56 PM
Luserkid's Avatar
Default Re: Exhaust Manifold Studs? (excivicboy96)
Put a vise grip to it and rotate.
Old 04-10-2007, 02:51 PM
ekb16's Avatar
a monkey wrench will do
Old 04-10-2007, 04:36 PM
Jay_Sensing's Avatar
A stout set of vice grips. It will be even easier if the motor is warm.
I replaced all of mine with studs from Honda not to long ago and that was the easiest way I found.
Old 07-07-2009, 11:51 PM
rexman2002's Avatar
>>>>OLD SCHOOL BUMP<<<<
where can I find these online?
I've noticed on bernardiparts.com that they only sell the nuts for the manifold, and the studs come with the complete head Anyone know other place where they don't charge 1700$ for 9 studs?
just looking to replace studs, as I broke 2, and would like to replace all while at it.
Old 07-07-2009, 11:55 PM
rexman2002's Avatar
exhasut manifold nuts
exhaust manifold studs... 1500$ wtf??
Old 07-08-2009, 12:08 AM
rexman2002's Avatar
where did you get those exactly??
Old 07-08-2009, 09:17 AM
rexman2002's Avatar
anyone?
Old 07-08-2009, 09:20 AM
92lxsleeper's Avatar
thread one nut onto it. then put a lockwasher on it, followed by another nut.
hold the outer most with a wrench, and turn the innermost counterclockwise, and this will tighten up the lockwasher, and when you hold the outer bolt, it will make the stud come out.
i tried with vise grips, and it didn't work, they kept rounding off.
Old 07-08-2009, 09:27 AM
EL Vap133's Avatar
www.hondaautomotiveparts.com
or
www.slhonda.com
maybe?
Old 07-08-2009, 09:54 AM
rexman2002's Avatar
Originally Posted by EL Vap133
found what I was looking for, thanks.
Last edited by rexman2002; 07-08-2009 at 03:35 PM. Reason: Edited to take out unnecessary comments.
Old 07-08-2009, 12:07 PM
EL Vap133's Avatar
First off, no need to get all hostile.
Second, do you need the studs that bolt the exhaust manifold to the head or the studs that hold the exhaust manifold to the collector pipe?
Third, have you tried any local junkayrds?
Try here: www.car-part.com
Old 07-08-2009, 02:19 PM
rexman2002's Avatar
what? hostile, about what? what did you edit?
I just asked that guy where he got the oem studs from.
the 9 studs that go into the head.
I'd rather replace all with new studs, than old rusted ones.
I will.
checked rockauto, all they have is nuts. Anyone know the size of the head studs, maybe I can source some at auto zone, or pepboys?
Old 07-08-2009, 02:32 PM
geneeunit's Avatar
go to the dealer, order how ever many you need of part# 90026-PT0-000 (thats item #12 in this diagram.)thats for single cam..
end thread.
Old 07-08-2009, 02:47 PM
rexman2002's Avatar
^^^how did you get that?
what website is that, can you order those online?
thanks!!...
EDIT: I'm an idiot and can't navigate an online parts catalog worth ****.
thank you geneeunit for the diagram and the part number.
/thread
Old 07-08-2009, 03:07 PM
geneeunit's Avatar
http://estore.honda.com/
you can always just go into your local dealer and tell them what you need, not all parts counter workers are douches.
Charlie Moua
03-14-2013 06:41 PM
invader_zim
01-24-2013 09:19 PM
stalyun
04-06-2010 06:47 AM
xrdriver
05-21-2006 05:34 PM
xEnderx
02-04-2006 07:36 AM
Quick Reply: Exhaust Manifold Studs?
