Blinking D4 Light & Check Engine Light? (97' civic, automatic tran.)
Old 04-09-2016, 02:00 PM
95Hatch_209's Avatar
Default Blinking D4 Light & Check Engine Light? (97' civic, automatic tran.)
97 civic, automatic transmission. Replaced the radiator yesterday, and some tranny fluid came out when doing so. So i added what i thought was lost and when i started it up and put it in reverse the check engine came on along with the "D4" light blinking. the car wont go now. When i accelerate the car doesnt respond like it should. I plugged an ob2 scanner in and "P0700 & P0758" came up. Please help. :'(
Old 04-09-2016, 03:52 PM
Needs to be About 20% Cooler
DieMaster's Avatar
Default Re: Blinking D4 Light & Check Engine Light? (97' civic, automatic tran.)
did you unplug anything to get the radiator out? go and check everything is pluged in good, no grounds are disconnected and check all your fuses are good.
Old 04-09-2016, 04:12 PM
Everything is plugged in correctly. Not sure about the fuses. Some tranny fluid was lost while replacing the radiator but i topped it off and checked the level and it was fine.
Old 04-09-2016, 06:41 PM
Former User's Avatar
You probably accidently unplugged the shift control solenoid. It's close to where you were working.
Marco_97
03-03-2011 04:57 AM
ice4me
11-30-2006 01:36 PM
pinoyboiwonder
12
02-03-2006 10:51 AM
nottswife
08-14-2005 07:31 PM
im_the_teacher
08-05-2003 11:02 PM
Quick Reply: Blinking D4 Light & Check Engine Light? (97' civic, automatic tran.)
