b20 engine mounts, help
In the "MOUNTS" section of this post:
https://honda-tech.com/zerothread?id=504321
Which are they in the following links:
99-00 Civic Si rear mount?
http://www.hondaautomotivepart...84%29
’94-00 Integra LS/GSR/Type R front transmission mount bracket?
http://www.acuraautomotivepart...y.jsp
’96-00 CRV, del-Sol VTEC driver’s side front lower engine mount bracket?
http://www.hondaautomotivepart...MT%29
I also want to add urethane inserts. Anyone have suggestions as to which kit to go with?
People dont want to go through the hassle of looking at numerous links to see what you want - you should have just posted the pics from the site (or searched....)
You want the engine's driver side bracket (bolts directly to block), rear tranny ("L") bracket, front lower tranny mount ALL sourced from an em1 (lower tranny all Bseries are identical)
And the p7j from a crv OR the p54 for AC w/ Dseries compressor
So, pic number 1, you want 7 and 10, also the unnumbered item (near E14-1 - available under Engine, and cylider block @ SLHonda)
2 - skip, order from pic set 1
3 - 1
3 - 1
Hey thanks for your reply! I remember you from HSTuners. Anywho, what did you mean when you said "available under engine, and cylinder block @SLHonda?" I located the E14-1 on Pic #1 but cannot reference the part that you are refering to. Also, would buying a prothane mounting kit for the EM1 be suitable? And what is a P7J and P54-are these the AC bracket from the CRV in pic#3 item 1?
Modified by zerovandez at 10:49 PM 8/9/2005
Number 8 here (you will need the studs from the d16 OR buy new ones...whichever you want to do)
11910-P30-000 BRACKET, ENGINE MOUNT $49.99
Apparently, a lot of people use the D's mount...but personally, Id use this (and I am), because its larger/beefier.
Yeah, p7j is the ac bracket #1 from the crv
P54 is the more expensive del sol one.
Either work fine
Couldnt tell you anything about inserts though.
Who were you on HST?
sweet, thanks for the clear up. Actually, I believe in the post about the b20 into an EK, the author states that this mount from a b20z is almost the exact same as one from the b16. So there's no need to replace it! saves me a couple of bucks! Any opinions on those Prothane bushings?
BTW, same name on HST. I like those forums too, lots of koo peeps
Modified by zerovandez at 2:46 AM 8/10/2005
BokudenNYC
04-28-2009 09:02 AM
Will Albers
09-30-2002 08:03 AM
