B16a 7300 rpm rev LIMIT? NO WAY!
Old 12-15-2014, 01:41 PM
BahrEJ6's Avatar
Default B16a 7300 rpm rev LIMIT? NO WAY!
sup guys
any one here have any info on why my swapped B16a gen 2 JDM only revs to 7300 rpm? by my understanding its making its 168hp at 7800 and its TORQUE at 7300. Why cant i go past this?
my previous engine was a d16z6 and yes my red line was 7300 also. same spot. im not planning on red lining OTD but i do race, and itd be nice to have that extra 1000 rpms when you need it.
I ran the jumper diagnostic and i got code 7 which is TPS sensor so im changing that but i do not think that that is the problem with my rev limit.
The ecu in there is the p28 that came with the motor. originally had the p30.
So after watching Inital D again could it be that im having the same problem as Takami? do i need a new cluster with a tachometer that will let me go that far? just a thought. btw my tach does go up to 9 stock so wtf?
any help would be badass idk if anyone has ever came across this problem.
Old 12-15-2014, 02:33 PM
Technical Hero
HondaPartsHero's Avatar
Default Re: B16a 7300 rpm rev LIMIT? NO WAY!
Fix your check engine light. Also is your ECU have a tune for the P30 or equivalent? If not there's an issue right there.
Old 12-15-2014, 02:49 PM
I never narc'd on nobody!
NotARaCist's Avatar
Are you seriously making cartoon references? Let me guess, you also know a guy named Harry. He's getting you two of them. The big ones. And you need them tonight.
The ECU controls the engine, and you are using the wrong ECU. The P30 is the correct ECU for that engine, and you should be using it. The P28 is the correct ECU for the D16Z6. Put the P30 on there, fix any CELs that may arise, and you'll be fine.
Old 12-15-2014, 04:46 PM
Chargerhemi06's Avatar
Your ecu is programmed for an automatic transmission.
Old 12-16-2014, 04:36 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
The D16Z6 ECU is programmed for a 7400 RPM limit.
This cannot be a serious post.
Old 12-17-2014, 08:48 PM
BahrEJ6's Avatar
Damn this website can be harsh.
First off a fucked up and said that the p28 is in there. It isnt. The p30 is. I got confused easy way to remember now... Bigger number bigger head. Yea. My bad.
And yes I made a cartoon reference. That show is dope. And yes again... This is a serious post. Sorry for mis leading yall with the info I gave. But, I had checked that already and somehow WORDED it backwards.
Anyway I'm fixing the TPS tonight. Guess ill let yall know what happens.
Its not the ecu!
Old 12-17-2014, 09:46 PM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Tach accurate?? I had mine of over a grand and spent almost a year thinking I couldn't rev to red line.
Drsexiestboy
22
09-20-2011 12:20 PM
b16a27
03-18-2005 12:27 AM
SOHC Gord
08-18-2004 12:02 PM
smokinvtecCRX18
15
03-30-2003 01:10 AM
skylinecivic
05-13-2002 01:49 PM
Quick Reply: B16a 7300 rpm rev LIMIT? NO WAY!
