b16a rev limiter 7k ??
Old Aug 17, 2004 | 06:21 AM
SOHC Gord's Avatar
Default b16a rev limiter 7k ??
okay i have a 91 hatch i put a b16a in turboed and everything is fine but it red lines at 7k and its got the pr3 ecu so it should go to 82k need to fix this problem tryed another ecu and it does the same thing does anyone have any input on how to wire this up or fix this problem. thanks
Old Aug 17, 2004 | 09:13 AM
SOHC Gord's Avatar
Default Re: b16a rev limiter 7k ?? (SOHC Gord)
help
Old Aug 17, 2004 | 10:23 AM
Malgerus's Avatar
Throwing any codes?
You may have been stuck with an Auto PR3 ECU, which redlines around there (assuming your tach is accurate).
Easy way to tell: Pull off the top of the ECU and look for a stamp. It should say "AT" or "MT" in big red letters. Obviously, "AT" means automatic.
Old Aug 17, 2004 | 11:03 AM
sleeperb16a's Avatar
Cant be the ECU. Auto PR3 has the rev limiter set at 7800rpm.
Old Aug 17, 2004 | 06:37 PM
SOHC Gord's Avatar
Default Re: b16a rev limiter 7k ?? (sleeperb16a)
hummm thanks for the ideas and info
Old Aug 17, 2004 | 07:55 PM
92eg6's Avatar
do u have a cel cause my b16 is redlinin at 6700 because of cel 22 vtec pressure switch
Old Aug 18, 2004 | 08:12 AM
SOHC Gord's Avatar
Default Re: b16a rev limiter 7k ?? (92eg6)
cel ? whats that
Old Aug 18, 2004 | 09:42 AM
Sliced Beard's Avatar
check engine light
and it is most likely the fact that your factory tach sucks and is not accurate like every Honda in existence
Old Aug 18, 2004 | 12:02 PM
SOHC Gord's Avatar
Default Re: b16a rev limiter 7k ?? (dirtyd463)
starting to figure a few things out
bobbo
Apr 28, 2005 02:29 PM
92CivicLS
Jan 28, 2005 11:30 AM
B16Anis
Apr 1, 2003 03:36 PM
Bugermass
Nov 17, 2002 01:39 AM
skylinecivic
May 13, 2002 01:49 PM
