b16. knocking. lose power. smoke form valve cover. help
Dat Dere Cell Tech
today on the way home from school i notcied loud loud knocking. it started last night. not very loud. but idle was lower than usual, substantially. id hit something in the road and assumed it was my exhaust. Anyways, i went to school this morning, a little louder, again thought it was exhaust. Today after school. LOUD LOUD LOUD. i got like 4 blocks. car died. started up. died. started again holding gas pedal, died. tried to start again..CLUNK. rancid smell. pulled off oil cap...SMOKE that was liek white. so whats wrong ?
Re: b16. knocking. lose power. smoke form valve cover. help (daklown)
Either valve and piston are damaged by timing belt slipping and causing everything to be out of sync... Timing belt must be really worn.
OR
YOu broke a piston rings.
OR
Re: (daklown)
Go check your oil, sounds like you fried the engine running it with no oil. Probably punctured the oil pan with the thing you hit in the road. Sorry more than likely you have screwed that engine pretty badly, but remember: everything is salvageable with the right amount of money.
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daklown »</TD></TR><TR><TD CLASS="quote">today on the way home from school i notcied loud loud knocking. it started last night. not very loud. but idle was lower than usual, substantially. id hit something in the road and assumed it was my exhaust. Anyways, i went to school this morning, a little louder, again thought it was exhaust. Today after school. LOUD LOUD LOUD. i got like 4 blocks. car died. started up. died. started again holding gas pedal, died. tried to start again..CLUNK. rancid smell. pulled off oil cap...SMOKE that was liek white. so whats wrong ? </TD></TR></TABLE>
If it was knocking real bad and then it died and wouldn't run again, added to the "white smoke" coming from your valve cover, I'd say you probably either cracked a sleeve (if the knocking was bad enough), ruptured the head gasket (and maybe hydrolocked) or cracked the head (valve/piston contact ).
What does the rancid smell smell like? How thick and cloudy is the white smoke from your valve cover? Are you sure it's not blue? Can you describe the knocking sound better? Will it crank at all? Do your accessories work?
Get back to us with more info. Good luck.
Re: b16. knocking. lose power. smoke form valve cover. help (SOHC_MShue)
A knock that rapidly progresses and causes a loss of power is usually a rod knock. The loud clunk and puff of smoke may have been the rod being thrown. Like the others said, pull the motor apart and inspect it. Inspect the outside of the block for cracks or holes where the rod may have come through.
Dat Dere Cell Tech
UPDATE
pulled valve cover:
timing belt in one piece.
still oil
i turned the crank pulley a ful lturn and then it got stuck..soo...
i tried starting again, with no plugs or valve cover and it sounded like it was turning over etc...so thats better. now what should i do ? im kindof a newb.
pulled valve cover:
still oil
Unceasing Measure
Re: (daklown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daklown »</TD></TR><TR><TD CLASS="quote">UPDATE
pulled valve cover:
still oil
i tried starting again, with no plugs or valve cover and it sounded like it was turning over etc...so thats better. now what should i do ? im kindof a newb.</TD></TR></TABLE>
That would be your starter turning the no-compression bottom end...therefore you have accomplished absolute 0. I agree that it sounds like rod knock. Were you watching the pistons when it happened? Were they all moving? Did one of them look busted (the rod, not the piston)?
pulled valve cover:
still oil
Dat Dere Cell Tech
i didnt take off the head, only the valve cover. i put it all back together and tried to start but only for like /5 seconds cause it make a LOUD SHRILL FAST knocking loud sound. that might help ?
Re: (daklown)
my money is on a broken rod... did you check the block all around and make sure there are no holes??? Also, remove the spark plugs, stick thin dowel rod down, and turn the motor, the rod should move up and down in every cylinder, meaning the piston is working
Dat Dere Cell Tech
so what happens when i push a dowel down a cylinder with a broken rod ?
so say a rod is broken, and i didnt penetrate the block, could i skate by with rods and new pistons if my cylinder wall is somehow okay ? and, what are the odds that it is ok ?
sleepergo
13
04-25-2017 01:49 PM
01hondaEX1.7_ky
Honda Civic (2001 - 2005)
05-01-2013 07:37 AM
p3anutboi
18
09-19-2011 02:29 AM
screwballz
12-28-2004 02:28 PM
