acceleration problem
Old 06-30-2009, 12:35 PM
HarosGSRek's Avatar
Default acceleration problem
alright so i swapped a gsr motor into my 98 civic.
my problem is when i step the gas pedal all the way down it sounds like it chokes up. doesnt rev up and sometimes even a pop from the throttle body.
but when i slowly give it gas it revs up perfectly fine. ive tried two different tb already thinking maybe its the tps sensor and theres no difference.
if anyone knows how to fix this problem or what can possibly be wrong id appreciate their input.
Old 06-30-2009, 12:37 PM
Matt93eg's Avatar
Default Re: acceleration problem
You don't have the clips for the TPS and MAP Sensor backwards do you?(IE:TPS clip plugged into the map and vice versa) They both look the same and will plug up to either one.
CEL on?
Old 06-30-2009, 12:46 PM
HarosGSRek's Avatar
i tried them both ways cause im not 100% sure which goes to which. yes cel is on. do you know what plug goes to what sensor? color wise.
Old 06-30-2009, 12:51 PM
Matt93eg's Avatar
Mine are basically:
Map:White/Yellow/Green
TPS:Yellow/Green/Red
However this is an LS...not GSR
Do you know what code the ECU is throwing? That could tell you ALOT right there.
Old 06-30-2009, 12:55 PM
I'm not Rick!
rick_rabies's Avatar
haro has these codes...
p1382 misfire/ignition
p0500 speed sensor
p0135 o2
p0141 o2
Old 06-30-2009, 01:02 PM
HarosGSRek's Avatar
yeah those are my codes.
Old 06-30-2009, 01:05 PM
HarosGSRek's Avatar
and these are the codes from last time.
p1298 filter
p0325 knocksensor
p0135 o2 sensor
p1337 misfire
p0141 o2 sensor
rick_rabies i cant remember which ones we already took care of
Old 06-30-2009, 01:24 PM
I'm not Rick!
the filter and the knock sensor.
but now its been 2 dif misfire codes.
ANYONE?
Old 06-30-2009, 01:36 PM
TravisCadello's Avatar
that is most definitely the TPS sensor or Timing is off! i hated that i had a Honda that did that! i would slowly more and more floor it to go fast lol. it was fun though.
Old 06-30-2009, 01:50 PM
HarosGSRek's Avatar
lol yeah it sucks. thanks for your help.
Old 07-01-2009, 05:45 AM
I'm not Rick!
i bet ben can fix it.
Old 07-01-2009, 05:50 AM
vtechjunkie's Avatar
That happened to mine once, and it turned out to be the dizzy. It also could be the fuel pump and filter.
Old 07-01-2009, 08:43 AM
I'm not Rick!
yeah get a new dizzy..try mine
Old 07-01-2009, 09:13 AM
slow96lude's Avatar
try checkin mechanical timeing sounds like the belt jumped a tooth
Old 11-27-2009, 01:22 PM
asianguy's Avatar
got same problem
Old 11-27-2009, 07:22 PM
-__-'s Avatar
^^wow yeah first check cam/crank timing. and DO NOT floor the car right now haha. what ECU do u have running it
allmotorgsr98
05-03-2011 11:32 PM
HarosGSRek
Engine Management and Tuning
07-01-2009 10:58 AM
steve0527
12-11-2006 05:53 AM
mugencivic94
10-26-2006 10:36 AM
Sanda1s
05-23-2006 09:42 PM
Quick Reply: acceleration problem
