AC on a swap??
Old 09-19-2007, 05:04 PM
XtymourX's Avatar
Default AC on a swap??
I might buy a car with a GSR motor in an EK coupe. It has no AC, i was curious, will the AC from a D series work, or does it have to be B series only?
also roughly how much do those run, i can install it
Old 09-19-2007, 06:10 PM
R81_EJ7's Avatar
the d-series a/c will work but you need to buy a b-series a/c bracket. http://www.icbmotorsports.com has what your looking for. i think its 92 bucks, then theres a lighter all aluminum one also.
Old 09-19-2007, 06:11 PM
R81_EJ7's Avatar
wait. just http://www.jdmland.com i spelled the other incorectly, same website. two url's.
Old 09-19-2007, 07:39 PM
red-si-eg..'s Avatar
Default Re: (hybrid-ej8)
yea the d-compressor will work. i got a 94 hatch with a 99 gsr and im runnin my stock compressor. but only 2 bolts will line up and the other2 will need to be clapped. thats if u dont want to spend too much money. or for a short fix. better line it up right or else u will be replacin the belt a coulpe of times.
Old 09-19-2007, 08:44 PM
JDMFreak's Avatar
Default Re: (red-si-eg..)
inlinefour has a a/c brack for about $125...
http://twincamtech.stores.yaho....html
check it out...
what i did was use the 2 right bolts and have someone welded on 2 left nuts and you can use your stock d-series compressor...due keep in mind...this was done with a b-series a/c bracket.
Old 09-19-2007, 09:27 PM
Default Re: (JDMFreak)
yea thats right forgot to mention that.. my bad..
Old 09-19-2007, 10:13 PM
XtymourX's Avatar
thanks a lot guys
1sikhatch
15
08-12-2010 01:51 PM
ek9child
06-10-2007 01:50 PM
fitbmx86
05-06-2007 11:48 PM
botlebruiser
03-07-2006 08:57 PM
Kal
05-25-2004 08:33 AM
Quick Reply: AC on a swap??
