AC question?
Old 10-17-2003, 07:42 PM
beanbean's Avatar
Default AC question?
Does anyone know what year was it that honda switched their AC systems to 134a refrigerant? Reason i ask is because i have a 92 SI and i would like to add AC. However, i will like a system that uses the 134a stuff so i can refill the the refrigerant at a later time without much hassel. Thanks.
Old 10-17-2003, 08:36 PM
chrisCNL's Avatar
Default Re: AC question? (beanbean)
1994 on all of the Honda vehicles. It is the law that all of the cars in the U.S. had to be using R134 by 1994.
Old 10-17-2003, 09:04 PM
solo2slocivic's Avatar
even if you get everything from another 92 you can retro it to 134 noa a big deal to do
Old 10-17-2003, 09:29 PM
BatuKing's Avatar
Default Re: AC question? (chrisCNL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo2slocivic &raquo;</TD></TR><TR><TD CLASS="quote">even if you get everything from another 92 you can retro it to 134 noa a big deal to do</TD></TR></TABLE>
no not true.. you will need to replace your reciever-drier and you will have to remove all components and take out as much of the mineral oil out of the system. Then you will have to replace it with PAG oil.
Please dont use those off the shelf refill 134A kits.. you will have problems.. Now the biggest thing is sealers.. If you refill it with sealant and you take it to a shop for inspection they will prob either refuse you or tell you go to somewhere else. So when you install the system in your car also please install the reciever-drier LAST and make sure you keep it capped when not installed.
So once done get it vaccumed and checked for leaks from someone professional.
Old 10-18-2003, 06:33 AM
beanbean's Avatar
Default Re: AC question? (BatuKing)
Thanks for the reply.....does anyone know what if there are any teg (94-01) or EK parts that i can use for my AC install? It will be hard trying to find a AC kit that is 8 to 9 years old. Thanks.
Old 10-18-2003, 07:19 AM
pro1342's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisCNL &raquo;</TD></TR><TR><TD CLASS="quote">1994 on all of the Honda vehicles. It is the law that all of the cars in the U.S. had to be using R134 by 1994. </TD></TR></TABLE>
Old 10-18-2003, 03:24 PM
Cynical 1's Avatar
Honda sells retrofit kits. Check a dealer.
Old 10-18-2003, 09:55 PM
KayOs's Avatar
retro kits have been discontinued. No longer available. Junk yard is your best bet.
Old 10-18-2003, 10:01 PM
BatuKing's Avatar
Actually the Federal law states the usage of R12 in New cars and production of CFC's is the end of 1995. But some manafactures opted to stop using it prior to this deadline.
but keep in mind when you do a retro-fit you need to change the O-rings to fit the new R134A.
1phatcivic
03-06-2008 06:24 AM
924doorEG
07-08-2007 04:07 PM
Kusai.Nihonjin.Desu
05-31-2004 02:19 PM
Quick Reply: AC question?
