Rattle sound at 2500 rpm in neutral and in gear
Old 05-06-2012, 06:02 AM
DELshaneSOL's Avatar
Default Rattle sound at 2500 rpm in neutral and in gear
Yesterday I change my tranny with a used new one did my flywheel and clutch kit from compition stage 2 with upgraded plate. I also got the lightweight steel flywheel
Now there's a sound at 2500rpm and it seems to only be at that rpm in gear or in neutral
It sounds like its comming from the tranny and is loud under the car?
Old 05-06-2012, 06:23 AM
92lxsleeper's Avatar
Default Re: Rattle sound at 2500 rpm in neutral and in gear
possibly input shaft bearing, throw out bearing, or pilot bearing
Old 05-06-2012, 06:32 AM
Pilot and throw out are new
Old 05-06-2012, 08:14 AM
Anything eles it could be, I can't really test the tranny because of clutch break in
Old 05-06-2012, 10:20 AM
CivicBlacksheep's Avatar
Check your fluid level in tranny
Old 05-06-2012, 10:24 AM
Fish Twig
tony_2018's Avatar
loose bolt probably? did you tighten down to spec?
Old 05-06-2012, 10:30 AM
Full with Honda 10w30
76 on fly and 20 on clutch
Old 05-06-2012, 10:43 AM
Fish Twig
tony_2018's Avatar
what about the t bracket bolts and trany bolts, exhaust manifold bolts? Just double check. doesn't hurt to look it over.
Old 05-06-2012, 10:52 AM
Arthas's Avatar
Honda 10w30? Why didnt you use Honda MTF?
Old 05-06-2012, 11:05 AM
I did Honda mtf I told them what tranny and they gave me the fluid
Old 05-06-2012, 06:13 PM
http://www.youtube.com/watch?v=e8rtvX2eE9I
Old 05-07-2012, 03:37 AM
Up
Old 05-07-2012, 05:21 AM
Seagull Management
94EG8's Avatar
Input/mainshaft bearing in the transmission is toast.
Old 05-07-2012, 05:32 AM
You can tell that from the video nice
About how much is that to fix?
Or is that easy to fix
Old 05-07-2012, 07:44 AM
Will I be ok driving it for a couple months?
And would a shaft beating make noise even when not in gear
Old 05-07-2012, 07:59 AM
Seagull Management
94EG8's Avatar
Sometimes yes, sometimes no. Seriously, I've seen some of them go a long time and do no other damage, sometimes they don't last that long and make a mess of the mainshaft.
Yes.
The bearing is about $20 figure another $5 or so for the seal that goes under it and $20 for a tube of Hondabond. It basically requires completely disassembling the trans, which isn't all that hard as long as you have a manual to go by.
nanagsr
03-30-2009 10:26 AM
vlc92189
14
11-27-2007 05:22 PM
B18EG6
01-26-2005 12:20 PM
fastlyfe
10-14-2004 02:16 PM
DMF
06-22-2003 07:42 PM
Quick Reply: Rattle sound at 2500 rpm in neutral and in gear
