96 ek sedan lx, headlight dim, flicker while hitting the brake.
Old 09-03-2011, 08:27 PM
wing.jai's Avatar
Default 96 ek sedan lx, headlight dim, flicker while hitting the brake.
headlight are bit dim on my ek sedan lx i realize when i step on the brakes it flicker and go dim a lil bit, battery is brand new, and alternator is still good. anyone ever dealt with this problem? car doesnt die out or anything everything runs normal, its just the headlight flicker when i hit the brake and light go dim.
wing.jai is offline
Old 09-03-2011, 08:29 PM
alphalanos's Avatar
Default Re: 96 ek sedan lx, headlight dim, flicker while hitting the brake.
has the alternator been tested
alphalanos is offline
Old 09-03-2011, 08:41 PM
wing.jai's Avatar
not it havent been tested, but i did replace the eld recently. what if i change it to a brand new altenator and its still the same problem?
wing.jai is offline
Old 09-03-2011, 09:17 PM
wing.jai's Avatar
was doing some reading they were saying it can be bad grounding but it doesnt seem like it i triple checkal the ground everything looks good, can anyone help?
wing.jai is offline
Old 09-03-2011, 09:35 PM
wing.jai's Avatar
RonJ@HT - i need your help on this one.!!
wing.jai is offline
Old 09-04-2011, 09:52 AM
wing.jai's Avatar
anyone?
wing.jai is offline
Old 09-04-2011, 10:10 AM
NACvicSi's Avatar
Check all your grounds. Then just take your alternator off and have it tested. Takes like 20min to pull it off.
NACvicSi is offline
Old 09-05-2011, 07:44 AM
wing.jai's Avatar
is there any ground in the interior>? anyone knoe where are the location for the ground inside the car?
wing.jai is offline
Old 09-05-2011, 10:06 PM
ej8slim's Avatar
I have the same problem with the stock ecu of my swap. I recently change my ecu to a P28 and I has help since the p28 ecu eld has been disabled.
ej8slim is offline
Old 09-05-2011, 11:33 PM
4drferio's Avatar
check ur wiring or alternator
4drferio is offline
Old 09-06-2011, 07:49 AM
wing.jai's Avatar
alternator wireing is good if it was bad the battery light will be on
wing.jai is offline
Old 09-06-2011, 10:04 AM
wing.jai's Avatar
altenator check - its good but headlight still flickers when you step on the brake. and headlight are still dimm
wing.jai is offline
Old 09-06-2011, 10:55 AM
alphalanos's Avatar
how did they test it. what voltage is it putting out. does the test say excessive ripple?
Old 09-06-2011, 03:10 PM
wing.jai's Avatar
took it to autozone, they test it with their machine, iforgot what was the voltage putting out,
wing.jai is offline
wing.jai
09-11-2011 09:42 AM
wing.jai
45
09-02-2011 06:39 PM
Cras-Delsol
07-16-2008 05:59 PM
creepy116
10-30-2007 09:36 AM
dc2_fanatic
12-25-2006 08:57 PM
Quick Reply: 96 ek sedan lx, headlight dim, flicker while hitting the brake.
