94 EG/B20B swap - misfire at low rpm and CEL does not work
Old 06-05-2012, 08:09 PM
arsalanshj's Avatar
Default 94 EG/B20B swap - misfire at low rpm and CEL does not work
car idles good and revs good only problem im getting when i rise rpm slowly it gives slide cuts off @ 1000 to 1500 rpm 1500 to 1000 it cut off when i unplug TPS its wont go above 2500 rpm whats is the problem i cant understand i tried to pull cel coded but cel light power have no power supply at all
Old 06-05-2012, 10:49 PM
jbpnoman's Avatar
Default Re: 1994 EG B20B swap
Try that again in a way that makes sense. While you're doing that, fix your CEL bulb (you probably just need to put one in), and check your ignition and mechanical timing.
Old 06-06-2012, 06:04 AM
Former User's Avatar
You must include some punctuation in your text. Otherwise it's difficult to decipher what the tech problem is.
Also, you thread title MUST summarize the tech problem - edited.
Start by fixing the CEL. Start by checking whether the CEL bulb was removed in the cluster.
EkDarin
04-14-2008 04:41 AM
ntensehonda
06-13-2006 03:40 PM
Quick Reply: 94 EG/B20B swap - misfire at low rpm and CEL does not work
