94 civic sohc vtec clicking noise
Old 10-25-2007, 07:20 AM
ge_ej1's Avatar
Default 94 civic sohc vtec clicking noise
i now have a clicking noise coming from my head of my engine, sounds like it is coming right underneath the valve cover....don't really know what's going on, but yeah its getting annoying
Old 10-25-2007, 07:24 AM
Probot's Avatar
Default Re: 94 civic sohc vtec clicking noise (ge_ej1)
could be a valve tap - take it to a mechanic, or if someone you know has done it, and get a valve adjustment - from time to time they have to be tightened down back to spec
Old 10-25-2007, 07:29 AM
raphael's Avatar
i have the same problem. its definetly a problem with single cams. get it re-adjusted or it could be your lma that need replacing
Old 10-25-2007, 07:40 AM
ge_ej1's Avatar
Default Re: (raphael)
how much will it cost to get it done?
Old 10-25-2007, 07:47 AM
Probot's Avatar
Default Re: (ge_ej1)
shouldn't be much, it really depends on how much the mechanic charges for labor and how long the job should take - i know there has to be a few guys on here that know how long it takes
Old 10-25-2007, 07:49 AM
1992Si's Avatar
With a few basic tools you can adjust the valves yourself.
Would you want to learn how?
Old 10-25-2007, 07:54 AM
Probot's Avatar
Default Re: (1992Si)
i know i definitely would
Old 10-25-2007, 09:12 AM
rivaladore's Avatar
Default Re: (Probot)
here's a DIY to adjust the valves https://honda-tech.com/zerothread?id=1305086
It's not too hard if you can follow instructions. I did it awhile ago when the only other thing I knew how to do was change my oil. Just Remember to let your car sit overnight bc it has to be cold.
Old 10-25-2007, 12:01 PM
SlaMMedB16's Avatar
Would this possibly have anything to do with my motor?
Sorry i dont want to jack this thread
But when i start my car and its still cold, i get a ticking noise until it fully warms up.
It eventually goes away but makes me wonder what it really is.
Old 10-25-2007, 12:04 PM
fmrprojects's Avatar
Default Re: 94 civic sohc vtec clicking noise (SlaMMedB16)
if you revving the **** outta your engine then a vlave adjustment is neccessary. if its just a stock motor then you should do one if you never had one done
d17beast
Honda Civic (2001 - 2005)
11-12-2010 03:12 PM
obuhmyuh
02-02-2008 12:00 AM
jdm_racer831
04-04-2007 08:49 PM
redlinex
09-19-2003 07:52 AM
lopey
02-26-2003 08:38 AM
Quick Reply: 94 civic sohc vtec clicking noise
